Positionnumber on which sheet
GeorgK
GeorgK
Hello together,
is there a possibility to a add a coloumn to the partlist for all position numbers and the corresponding sheetname?
Pos.Nr. 1 - Sheet2
Pos.Nr. 2 - Sheet1
Pos.Nr. 3 - Sheet1
Pos.Nr. 4 - Sheet3
Thank you
Georg
Replies (8)
Sergio.D.Suárez
Hi, I think that once I faced something similar, I have a drawing with many sheets, each sheet with different views of parts of an assembly. This rule creates a custom property in each part, which indicates the sheet in which it is located in the drawing.
I have simplified the rule so that it is easy to interpret.
You can modify the values to identify the drawing file
Dim oDoc As DrawingDocument = ThisDoc.Document
oSheets = oDoc.Sheets
myparam = InputBox("Defines the location location on a sheet", "Location on a sheet", "H")
For Each oSheet As Sheet In oDoc.Sheets
	For Each oView As DrawingView In oSheet.DrawingViews
	oViewModelDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
	oModelName = oView.ReferencedDocumentDescriptor.ReferencedDocument.DisplayName
	Dim SheetNumber As String = Mid(oSheet.Name, InStr(1, oSheet.Name, ":") + 1)
	Dim customPropSet As PropertySet = oViewModelDoc.PropertySets.Item("Inventor User Defined Properties")
    On Error Resume Next
    customPropSet.Item(myparam).Value = SheetNumber
	    If Err.Number <> 0 Then
	    	customPropSet.Add(SheetNumber, myparam)
   		End If
	Next
Next
 I hope to be clear and that this will help solve your problem.
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
GeorgK
Hello @Sergio.D.Suárez ,
thank you very much. I'll give it a try.
Georg
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
Can you please elaborate your requirement with examples? Make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
bradeneuropeArthur
This will guide you in the correct direction i think!
Public Sub main()
Dim a As Application
Set a = ThisApplication
Dim b As DrawingDocument
Set b = a.ActiveDocument
Dim c As Balloon
Set c = b.ActiveSheet.Balloons.Item(1)
Dim v As DrawingView
Set v = c.ParentView
MsgBox v.Parent.Name
End Sub
Please let me know if you need further assistance....
Arthur Knoors
Autodesk Affiliations:
GeorgK
Hello @chandra.shekar.g ,
I would like to add a column with the sheet number in which the position number is placed.
Thank You
Georg
bradeneuropeArthur
Public Sub main()
Dim c As Balloon
For Each c In b.ActiveSheet.Balloons
Dim p As PartsList
Set p = b.ActiveSheet.PartsLists.Item(1)
p.PartsListRows.Item(1).Item("Sheet").Value = v.Parent.Name
Next
End Sub
Arthur Knoors
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
Work around from @bradeneuropeArthur seems to be fine.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
GeorgK
@bradeneuropeArthur
Thank you very much.
Georg
