Announcements
Populating my parameters using iLogic
tecnico3S7Z5
tecnico3S7Z5
Currently I'm using a code of iLogic I found to populate my parameters from the parent assembly to it's child components
Public Sub Main()
	CopyUserParams()
End Sub
Private Sub CopyUserParams()
    If ThisDoc.Document.DocumentType <> Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
        MsgBox("The active document must be an assembly.")
        Return
    Dim asmDoc As Inventor.AssemblyDocument = ThisDoc.Document
    For Each refDoc As Inventor.Document In asmDoc.AllReferencedDocuments
        ' Look for part documents.
        If refDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
            Dim partDoc As Inventor.PartDocument = refDoc
            Dim refDocUserParams As UserParameters = partDoc.ComponentDefinition.Parameters.UserParameters
            ' Add the assembly parameters to the part.
            For Each asmUserParam As UserParameter In asmDoc.ComponentDefinition.Parameters.UserParameters
                ' Check to see if the parameter already exists.
                Dim checkParam As UserParameter = Nothing
                Try
                    checkParam = refDocUserParams.Item(asmUserParam.Name)
                Catch ex As Exception
                    checkParam = Nothing
                End Try
                If checkParam Is Nothing Then
                    ' Create the missing parameter.
                    refDocUserParams.AddByExpression(asmUserParam.Name, asmUserParam.Expression, asmUserParam.Units)
                Else
                    ' Update the value of the existing parameter.
                    checkParam.Expression = asmUserParam.Expression
            Next
    Next
	iLogicVb.UpdateWhenDone = True
End Sub
The issue is that this code only spreads the parameters to it's child components (the ".ipt"s) but it doesn't spread the parameters to it's child assemblies (the ".iam"s don't receive the parameters). So, my question is; how can I modify this code so it populates the parameters to all it's child elements both the sub-asseblies and the child components?
Thanks for reading!
WCrihfield
Hi @tecnico3S7Z5.  It looks to me like this one 'check' in your code, at Line 14 is where the issue is.
 You would need to eliminate that line of code, and also the 'End If' line of code that would be closing that 'If statement' out, later in the code.  Then, eliminate that next line after that line, where it is declaring a variable (partDoc) as a more specific document type (PartDocument).  However, if you do that, you will need to conduct a search & replace to find all instances of that 'partDoc' variable, and replace them with the 'refDoc' variable, to avoid those potential errors.
Wesley Crihfield
(Not an Autodesk Employee)
Curtis_Waguespack
Hi @tecnico3S7Z5
Welcome to the forum.
Here's am updated version of this addressing the point that WCrihfield made as well as the issue that would occur when there are true/false and text parameters present.
Hope that helps,
Curtis
	Return
Dim asmDoc As AssemblyDocument = ThisDoc.Document
	Dim refDocUserParams As UserParameters = refDoc.ComponentDefinition.Parameters.UserParameters
	' Add the assembly parameters to the component document
		Try
			newParam = refDocUserParams.Item(asmUserParam.Name)
			If asmUserParam.Units.ToString = "Boolean" Or asmUserParam.Units.ToString = "Text" Then
				newParam = refDocUserParams.AddByValue(asmUserParam.Name, asmUserParam.Value, asmUserParam.Units)
			Else
				newParam = refDocUserParams.AddByExpression(asmUserParam.Name, asmUserParam.Expression, asmUserParam.Units)
		End Try
		If Not newParam Is Nothing Then newParam.Expression = asmUserParam.Expression
	Next
Next
tecnico3S7Z5
Thank you everyone for your help! you saved me, really appreciate
