Populate Excel with iproperties using iLogic.
Thomas_Savage
Thomas_Savage
I am trying to populate an excel spread sheet using iLogic.
I have attached the code and where my excel sheet is saved.
It keeps saying that it can't find the excel spread sheet.
Can anyone help??
Or does anyone have a code i could use to populate an excel spread sheet, using i properties. Part number for example.
Thomas
Thomas Savage
Design Engineer
Thomas_Savage
Problem Solved,
I didnt place the full location.
Also excel files needs to be closed when you run the code, else it will not update. Then when you update, the information will appear.
Just in case anyone else is having the same problem.
Thomas
Thomas Savage
Design Engineer
