Points on 3D spline
GeorgK
Points on 3D spline
GeorgK
Hello together,
how could I get the points on a 3D spline? The points should be calculated for example 2mm along the spline.
I could export the points:
http://modthemachine.typepad.com/my_weblog/2011/06/writing-work-points-to-an-excel-file.html
Thank you Georg
Replies (8)
GeorgK
I think it's possible with 3d spline interpolation. Is there any function in Inventor to do this?
JaneFan
Hey Georg,
Was the 3d spline created with the points? If so, it is convenient to get the sketch points by SketchSpline3d.FitPoint(Index) in Inventor.
Jane Fan
Inventor QA Engineer
GeorgK
Hello @JaneFan,
the 3d spline was created with the points. Do you have a sample code for this?
Thank you Georg
JaneFan
Hey Georg,
Please find the following code to get some hint, which adds all fit points of a spline 3d to an object collection
Sub splintPts()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oSk3d As Sketch3D
    Set oSk3d = oDoc.ComponentDefinition.Sketches3D(1)
    Dim oSkSpline As SketchSpline3D
    Set oSkSpline = oSk3d.SketchSplines3D.Item(1)
    Dim objCol As ObjectCollection
    Set objCol = ThisApplication.TransientObjects.CreateObjectCollection
    For i = 1 To oSkSpline.FitPointCount
        Call objCol.Add(oSkSpline.FitPoint(i))
    Next
    Debug.Print objCol.Count
End Sub
Jane Fan
GeorgK
Hi Jane,
maybe I explained the problem wrong. I need the points along the spline with a given distance.
Thank you
Georg
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @GeorgK,
Hope the following screencast link would help.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/screencast/Main/Details/...
In this screencast video, workpoint is created at one of the end point. Then, workpoint is patterned along curve length.
Similarly, a rectangle patterned part is attached with this post. Here, pattern count is calculated by measuring length of curve divided by offset length.
Can you please provide sample part to test? please make sure that part is non confidential one.
Please feel free to contact if there is any queries.
If problem is solved, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
GeorgK
Hello @chandra.shekar.g,
I thought that there could be a possibility to calculate the points directly. I have a robot which should drive along the spline. There are a lot of calculations to this.
Thanks Georg
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @GeorgK,
Unfortunately, there is no direct approach to calculate the points along spline.
Please post this wish list at idea station using following link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232/tab/most-recent
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
