Announcements
Planning - Rule Doesn't Work!
iva.btblan
iva.btblan
Why doesn't the rule work?
Different dimensions.
Rule does not work.
How to solve it?
Can someone help me?
bradeneuropeArthur
Take a look at the flat-pattern orientation in the ipt file!
by:
select Flat-pattern
Right Mouse Click
Go to flat pattern.
Change the orientation to the XYZ axis as needed to display correctly. (This could have a rotation!!!)
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
iva.btblan
Excellent!   Thanks!
bradeneuropeArthur
Could you please mark the solution as solved and not the reply to the solution, as it is usual.
For administration reasons this is the usual way of doing it.
Thank you for your understanding.
Hope that you will mark the solution in future too,
Best regards,
Arthur Knoors
