Placing a Part in the same position in an Assembly Using iLogic
I'm trying to develop an application that automates a process. I place a Part in a specific position in the Assembly and I would like to copy this part as many times as I want and place it in the same position using programming.
I'm using VBA for this inside de iLogic in Inventor 2018.
bradeneuropeArthur
That goes also without programming!
Curious?
In the application options change:
Add a component pattern with distance "0" and a Qty and you need for this component
Arthur Knoors
Autodesk Affiliations:
Michael.Navara
Here is sample code for "Copy occurrence" to the same position
Dim asmDef As AssemblyComponentDefinition = ThisDoc.Document.ComponentDefinition
Dim occ As ComponentOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Pick Occurrence")
Dim occDocument As Document = occ.Definition.Document
Dim occDocumentName As String = occDocument.FullDocumentName
Dim position As Matrix = occ.Transformation
Do
	asmDef.Occurrences.Add(occDocumentName, position)
Loop While (MsgBox("Again?", MsgBoxStyle.YesNo + MsgBoxStyle.Question) = MsgBoxResult.Yes)
