Place dimension on part sketch text box
jorgen.bjornes
Message 1 of 8
jorgen.bjornes
I am playing with, and expanding on the excellent part number mark ilogic rule by  @JelteDeJong to fit my own needs :
http://www.hjalte.nl/82-addmarkfeature
I want to control the text box size and formatting. I am able to control size and justification, and show the text box geometry, but in addition I would like to dimension the text box to fix it. Otherwise it might change when part geometry changes. Worst case it even flips. Dimensioning it
This part is working today;
        Dim formatedText = String.Format("<StyleOverride FontSize='{0}'>{1}</StyleOverride>", textHeight, markText)
		Dim sketchText = sketch.TextBoxes.AddFitted(modelPoint, formatedText)
		sketchText.Height = 4 '.Style.Justification=1
		sketchText.Width = 50
		sketchText.Style.HorizontalJustification = 19969   '	Text centered about the supplied point.
		sketchText.Style.VerticalJustification = 25601
		sketchText.ShowBoundaries() = True
But I'd like to add parametric dimensions in addition to really fix the text box no matter what happens with the face the sketch and text box is placed on. Like this:
But here I am stuck.. Is this at all possible?
Replies (7)
Message 2 of 8
Andrii_Humeniuk
Hi @jorgen.bjornes . This is an example of creating a dimension to the border of a TextBox for a sketch in a part with user parameters:
Dim oInvApp As Inventor.Application = ThisApplication
Dim oTG As TransientGeometry = oInvApp.TransientGeometry
Dim oPDoc As PartDocument = oInvApp.ActiveDocument
Dim oPDef As PartComponentDefinition = oPDoc.ComponentDefinition
Dim oUsParams As UserParameters = oPDef.Parameters.UserParameters
Dim oSketch As PlanarSketch = oPDef.Sketches(1)
Dim oText As Inventor.TextBox = oSketch.TextBoxes(1)
Dim oDimH, oDimW As TwoPointDistanceDimConstraint
For Each oLine As SketchLine In oText.BoundaryGeometry
	Dim oS As Point2d = oLine.Geometry.StartPoint
	Dim oM As Point2d = oLine.Geometry.MidPoint
	Dim oE As Point2d = oLine.Geometry.EndPoint
	If oS.X = oE.X And oDimH Is Nothing Then
		Dim oPText As Point2d
		oPText = oTG.CreatePoint2d(oS.X - 1, oM.Y)
		oDimH = oSketch.DimensionConstraints.AddTwoPointDistance(oLine.StartSketchPoint,
														oLine.EndSketchPoint,
														DimensionOrientationEnum.kVerticalDim,
														oPText,
														False)
		oDimH.Parameter.Expression = oUsParams("d_H").Name
	Else If oS.Y = oE.Y And oDimW Is Nothing Then
		oPText = oTG.CreatePoint2d(oM.X, oS.Y+1)
		oDimW = oSketch.DimensionConstraints.AddTwoPointDistance(oLine.StartSketchPoint,
														DimensionOrientationEnum.kHorizontalDim,
														oPText,
														False)
		oDimW.Parameter.Expression = oUsParams("d_W").Name
Next
In the example, the height parameter is d_H (Line 21), and the width parameter is d_W (Line 30). So you need to type in the names of your parameters.
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Message 3 of 8
jorgen.bjornes
Oooohh. Thank you thank you thank you!
I'll certainly test it out later tonight and see if I can wrap my head around this code and make it work in my rule.
Will get back and report! 🙂
Message 4 of 8
jorgen.bjornes
This worked great. I hardly had to adapt anything, it worked on copy-paste. Impressed with your ilogic ninja skills 🙂
I commented out line 21 and 30 though, as I just wanted the dimensions to fix and stabilize the text box.
Only thing I need to do after I place the part number mark on a face is to manually constrain the placement;
Message 5 of 8
swalton
I'm trying to build a rule to add the part number and revision as a mark feature in our parts.
This code looks like it might help, but I keep getting an error from line 7 when I try to run it.
Any suggestions on how to update the sample code or my system to get this to run?
I'm currently on
Steve Walton
Inventor 2025
Vault Professional 2025
Message 6 of 8
jorgen.bjornes
Steve, I ended up with the following code that I am happy with and it addresses our needs. Works well in both 2023 and 2025. Maybe you can use it (or parts of it):
Public Class ThisRule
    Sub Main()
oDoc = ThisDoc.Document
oNamer = "Highlight Dimension Overrides"
Dim UNDO As Transaction
UNDO = ThisApplication.TransactionManager.StartTransaction(oDoc, oNamer)
'---- Undo Wrapper
If ThisApplication.ActiveDocument.DocumentType = kPartDocumentObject Then 'OK, run his
        Dim markStyleName = "Mark Surface"
        Dim markText = iProperties.Value("Project", "Part Number")
        Dim textHeight = 3 'Cm
If (String.IsNullOrWhiteSpace(markText)) Then
MsgBox("Part Number property not set. Part not saved yet?",, "No mark text")
Return
        Dim selector As New Selector(ThisApplication)
        selector.Pick()
If (selector.SelectedObject Is Nothing) Then Return
        Dim face As Face = selector.SelectedObject
        Dim pointOnFace As Point = selector.ModelPosition
        CreateMarkFeatur(face, pointOnFace, markStyleName, markText, textHeight)
Else
MessageBox.Show("Please use on part document. Inplace edit not yet supported")
' Undo Wrapper -------------------------------------------------------------------------------------
UNDO.End
    End Sub
    Private Sub CreateMarkFeatur(face As Face, pointOnFace As Point, markStyleName As String, markText As String, textHeight As Double)
        Dim doc As PartDocument = ThisDoc.Document
        Dim def As PartComponentDefinition = doc.ComponentDefinition
'messagebox.Show("about to crash if edit in assembly")
        Dim sketch = def.Sketches.Add(face)
        Dim modelPoint As Point2d = sketch.ModelToSketchSpace(pointOnFace)
sText = "<Property Document='model' FormatID='{32853F0F-3444-11d1-9E93-0060B03C1CA6}' PropertyID='5' /> " 'Using actual property, not value
        Dim formatedText = String.Format("<StyleOverride FontSize='{0}'>{1}</StyleOverride>", textHeight, sText)
'--------------- add dims To Text box---------------------
Dim oText = sketchText 'As Inventor.TextBox = oSketch.TextBoxes(1)
oPText,
False)
' oDimH.Parameter.Expression = oUsParams("d_H").Name
oPText,
False)
' oDimW.Parameter.Expression = oUsParams("d_W").Name
Next
'-------dim text box end -------------------------
        Dim markGeometry As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection()
        markGeometry.Add(sketchText)
        Dim markFeatures As MarkFeatures = def.Features.MarkFeatures
        Dim markStyle As MarkStyle = doc.MarkStyles.Item(markStyleName)
        Dim markDef As MarkDefinition = markFeatures.CreateMarkDefinition(markGeometry, markStyle)
If (ThisApplication.SoftwareVersion.Major >= 28) Then
' The following property was introduced in Inventor 2024
' Therefore we can't set this property before Inventor 2024
' If this is not set after Inventor 2023 the rule fails most of the time.
' (Major version 28 = Inventor 2024)
markDef.Direction = PartFeatureExtentDirectionEnum.kNegativeExtentDirection
        markFeatures.Add(markDef)
'-----------------------Renaming feature name tp "PN".
'First Get the last feature
Dim lastFeature As PartFeature
lastFeature = ThisDoc.Document.ComponentDefinition.Features.Item(ThisDoc.Document.ComponentDefinition.Features.Count)
'MessageBox.Show(lastFeature.Name)
' Define the base new feature name
Dim baseFeatureName As String
baseFeatureName = "PN"
' Initialize the new feature name with the base name
Dim newFeatureName As String
newFeatureName = baseFeatureName
' Check if the new feature name already exists and add a number if needed
Dim counter As Integer
counter = 2
While FeatureNameExists(newFeatureName)
    newFeatureName = baseFeatureName & counter.ToString()
    counter += 1
End While
' Rename the last feature
On Error Resume Next
lastFeature.Name = newFeatureName
'If Err.Number <> 0 Then
    ' MessageBox.Show("Failed to rename the feature. The name might already be in use.", "Error")
    ' Err.Clear()
'Else
'    MessageBox.Show("The last feature has been renamed to " & newFeatureName, "Success")
'End If
sketch.Edit
    End Sub
' Function to check if a feature name already exists
Function FeatureNameExists(featureName As String) As Boolean
    Dim feat As PartFeature
    For Each feat In ThisDoc.Document.ComponentDefinition.Features
        If feat.Name.ToUpper() = featureName Then
            Return True
    Next
    Return False
End Function
End Class
Public Class Selector
    Private WithEvents _interactEvents As InteractionEvents
    Private WithEvents _selectEvents As SelectEvents
    Private _stillSelecting As Boolean
    Private _inventor As Inventor.Application
    Public Sub New(ThisApplication As Inventor.Application)
        _inventor = ThisApplication
    End Sub
    Public Sub Pick()
        _stillSelecting = True
        _interactEvents = _inventor.CommandManager.CreateInteractionEvents
        _interactEvents.InteractionDisabled = False
        _interactEvents.StatusBarText = "Select a point on a face."
        _selectEvents = _interactEvents.SelectEvents
        _selectEvents.WindowSelectEnabled = False
        _interactEvents.Start()
        Do While _stillSelecting
            _inventor.UserInterfaceManager.DoEvents()
        Loop
        _interactEvents.Stop()
        _inventor.CommandManager.StopActiveCommand()
    End Sub
    Public Property SelectedObject As Face = Nothing
    Public Property ModelPosition As Point = Nothing
    Private Sub oSelectEvents_OnPreSelect(
            ByRef PreSelectEntity As Object,
            ByRef DoHighlight As Boolean,
            ByRef MorePreSelectEntities As ObjectCollection,
            SelectionDevice As SelectionDeviceEnum,
            ModelPosition As Point,
            ViewPosition As Point2d,
            View As Inventor.View) Handles _selectEvents.OnPreSelect
        DoHighlight = False
        If TypeOf PreSelectEntity Is Face Then
            If TypeOf PreSelectEntity.Geometry Is Plane Then
                DoHighlight = True
    End Sub
    Private Sub oInteractEvents_OnTerminate() Handles _interactEvents.OnTerminate
        _stillSelecting = False
    End Sub
    Private Sub oSelectEvents_OnSelect(
            ByVal JustSelectedEntities As ObjectsEnumerator,
            ByVal SelectionDevice As SelectionDeviceEnum,
            ByVal ModelPosition As Point,
            ByVal ViewPosition As Point2d,
            ByVal View As Inventor.View) Handles _selectEvents.OnSelect
        SelectedObject = JustSelectedEntities.Item(1)
        If TypeOf SelectedObject Is Face Then
            If TypeOf SelectedObject.Geometry Is Plane Then
                Me.SelectedObject = SelectedObject
                Me.ModelPosition = ModelPosition
    End Sub
End Class
Message 7 of 8
swalton
Jorgen,
Your code is very helpful.  I've been able to modify it to use a form to set the text height and call a specific Mark Feature style from the Style Library.
I like how you are using the actual Part Number parameter for the text string.  My next challenge is getting the feature text to read <Part Number>r<Revision Number>.  Can you point me to where to find the code for Revision Number?
Similar to: "<Property Document='model' FormatID='{32853F0F-3444-11d1-9E93-0060B03C1CA6}' PropertyID='5' /> " 'Using actual property, not value
Steve Walton
Inventor 2025
Message 8 of 8
swalton
After some digging, it looks like the Object Browser from the VBA Editor on the Tools tab is the way to get the rev number property codes.
See: https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=GUID-69AD62A5-2D23-4F61-8412-3DA1F3865E30
And the response in this post https://forums.autodesk.com/t5/inventor-forum/how-to-access-object-browser/td-p/8928377:
@mcgyvr wrote:
@Anonymous  In Inventor.. Go to Tools Ribbon and in the Options pane press the "VBA editor" button.. When that program opens go to ..View.. Object Browser
(Quoted because of the 10 year delete rule)
Steve Walton
Inventor 2025
