Place assembly view from dialog box
jishee
jishee
I have some iLogic written to place a view of an assembly in my drawing sheet to the scale I want. Is there a way to use a dialog box to select the assembly file I want to use rather than specify the full path in the code?
jishee
Here is the code.
Dim oPartDoc As AssemblyDocument
oPartDoc = ThisApplication.Documents.Open("C:\Users\jishee\Documents\Work\Inventor_modeling\Dimensioning_Test\U001_Assembly.iam", False)
Dim oDrawingDoc As DrawingDocument
oDrawingDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawingDoc.Sheets.Item(1)
Dim oPoint1 As Point2d
oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(4.5#, 6#)
Dim oView1 As DrawingView
oView1 = oSheet.DrawingViews.AddBaseView(oPartDoc, oPoint1, 0.03125#, kFrontViewOrientation, kHiddenLineRemovedDrawingViewStyle)
ActiveSheet.View(oView1.Name).SetCenter(4.5, 6)
Call oPartDoc.Close(True)
JhoelForshav
I added i filebrowser to select iam file to your code. Is this what you're looking for? :slightly_smiling_face:
Dim oDlg As Inventor.FileDialog
ThisApplication.CreateFileDialog(oDlg)
oDlg.Filter = "Inventor Assembly Files (*.iam)|*.iam"
oDlg.ShowOpen() ' to open files
If oDlg.FileName = "" Then Exit Sub
oPartDoc = ThisApplication.Documents.Open(oDlg.FileName, False)
Dim oSheet As Sheet
JhoelForshav
@jishee
Here is an example if you want to be able to select ipt and ipn  aswell.
Also in this example i added code so that if the file is already open in inventor, it doesnt close it when the rule is done.
If it isn't already open however, the file gets closed like in the previous code.
With oDlg
	.Filter = "Assembly File (*.iam)|*.iam" _
	& "|Part File (*.ipt)|*.ipt" _
	& "|Presentation File (*.ipn)|*.ipn"
	.FilterIndex = 1
	.InitialDirectory = ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath
End With
'oDlg.Filter = "Inventor Assembly Files (*.iam)|*.iam"
Dim oDoc As Document
Dim CloseWhenDone As Boolean = False
Try
oDoc = ThisApplication.Documents.ItemByName(oDlg.FileName) 'Get the document if it's already open.
Catch
oDoc = ThisApplication.Documents.Open(oDlg.FileName, False)
CloseWhenDone = True 'If document wasn't already open, close it again after view is placed.
End Try
Dim oSheet As Sheet
oView1 = oSheet.DrawingViews.AddBaseView(oDoc, oPoint1, 0.03125#, kFrontViewOrientation, kHiddenLineRemovedDrawingViewStyle)
If CloseWhenDone Then oDoc.Close(True)
