Hi there,
I'm running into a small problem with my ilogic rule where I have a variable to set to a component occurrence object using the kAssemblyOccurrenceFilter. On individual occurrences it works fine but it seams to somehow switch to kAssemblyLeafOccurrenceFilter when trying to select a occurrence in an assembly pattern. Unless I select the occurrence in the model tree it seems to only let me select the individual parts in the sub-assembly.
My questions being
1. Why does it do that?
2. How do I have it so it selects the assembly occurrence instead?
Link copied
