- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I know this has probably been beat to death but I can't find the step that I am missing, it's probably extremely obvious:
Need help on step 6, bold text.
Steps 1-6 show the method I am using to pattern a part in an assembly along a 3D curve.
1. create a new part. In the part draw a 3D spiral, the length of the stairway with a suitable number of turns.
2. draw a feature (cube, cylinder etc) that you can then pattern along this curve. The feature can be anything. Its going to be used as a reference later. To pattern it use a rectangular pattern, but select the spiral as the direction. You need to adjust the setting of the pattern to make the feature orientation adjust as it patterns along the spiral.
3. create a model of a step
4. create a new assembly file and assemble the spiral part.
5. assemble the step to into the assembly
6 pattern the step using the patterned feature in the spiral part as the reference. The step will be patterned the same number of times as the feature in the spiral
Step 6 in bold is where I am not getting it: When I select "Pattern" in the Assemble Tab(in my assembly), I can select my part as the component, but my rectangular pattern does not show up anywhere in the browser or on-screen as the "Feature Pattern Selection" option.
