Pattern of a pattern using ilogic
Wind_Talker
Wind_Talker
Hi All,
I have a bolt which has been assembled 3 times in an assy. Then this bolt is patterned around the axis of the part using circular pattern command. Let's call this pattern A. So now, Pattern A has 2 instances Element 1 and Element 2 and each instance have 3 bolts in it.
Pattern A is again patterned "n" no of times around another axis using circular pattern command. So now, pattern A is sitting inside another pattern. Let's call it Pattern B.
So Pattern B is the top level pattern which contains pattern A as its instances "n" no of times. Pattern A then contains 2 instance as given above. I also have same bolt existing in the model tree outisde pattern B.
I need iLogic code to do component replace on the bolt inside pattern B. The code should replace all instaces of the bolts but only inside the pattern B. Any bolt existing outside pattern B should remain unchanged.
Can anyone help with this please? I have searched internet to find something similar but no luck.
Thanks in advance.
Owner2229
Hi, you can try this:
Dim PatternName As String = "Component Pattern 1:1" ' This is the Pattern you want to search for
Dim OldFile As String = "MyFile1"                   ' This is the part you want to replace, without extension
Dim NewFile As String = "C:/MyPath/MyFile2.ipt" ' This is the replacing part, full path Dim oDoc As Document = ThisApplication.ActiveDocument Dim oOcc As ComponentOccurrence For Each oOcc In oDoc.ComponentDefinition.Occurrences Dim oName As String = oOcc.Name
Dim FNP As Integer = InStrRev(oName, ":", -1)
oName = Left(oName, FNP - 1)
If Not oName = OldFile Then Continue For
Try If Not oOcc.PatternElement.Type.ToString = "kOccurrencePatternElementObject" Then Continue For Catch Continue For End Try Dim oElement As OccurrencePatternElement = oOcc.PatternElement Dim oParent As Object = oElement.Parent If oParent.Name = PatternName Then oOcc.Replace(NewFile, False) ' False to not replace all occurrences End If Next
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Wind_Talker
Hi Mike,
Thanks for your code. When using it, following line give me an error.
 The error is
Argument 'Length' must be greater or equal to zero.
My guess is this is happening because I am not using default inventor names for bolts. Rather I am using my own defined names as "BR BOLT 1" "BR BOLT 2" and "BR BOLT 3".
Any idea?
regards
Wind_Talker
I have come up with the following code which works fine but I hate the fact that I have to hard code the names of each parent bolt in component.replace command. See the code below.
Dim oDoc As AssemblyDocument
    oDoc = ThisApplication.ActiveDocument
Dim oPattern As OccurrencePattern
    oPattern = oDoc.ComponentDefinition.OccurrencePatterns.Item("BR STRING FASTENER SET")
    oElements = oPattern.OccurrencePatternElements
Dim i As Integer
For i = 1 To oElements.Count
    Dim OCCS As OccurrencePatternElement
        OCCS = oElements(i).Components(1).OccurrencePatternElements(1)
    For Each OCCS In oElements
        Try
            Component.Replace("BR BOLT 1", "File name to replace with including path", False)
            Component.Replace("BR BOLT 2", "File name to replace with including path", False)
            Component.Replace("BR BOLT 3", "File name to replace with including path", False)
        Catch
            'some code here
End Try Next Next InventorVb.DocumentUpdate()
As I understand, this code is replacing only the parent or master component. The rest of the occurrances are replaced or updated due to fact that they are the pattern of this master component. In this case the master components are 3 bolts.
Anyway it works!!
Cheers
duans5FLJC
Observer
Observer
Is there a way to not have to hard code the pattern name? So that I can loop through occurrences in an assembly and suppress that "top-level" pattern.
