Passing multiple paramters from a form to a part - How do I delay update?
DSilver4773
DSilver4773
I am working on a project where I am using a form to input two parameter values that will drive an assembly/part update. The problem I am having is that as soon as I enter one of the parameters the part updates before I am able to enter the second parameter. This is problematic as I have additional ilogic scripts that creates new parts/assemblies based on the new parameters and it executes on the 1st parameter update. Is this possible using Forms or is there a preferred method of achieving this? I have attached a sample part with with a form and an iLogic rule.
JhoelForshav
Hi @DSilver4773
If you change the predefined buttons in the form to OK Cancel Apply it will wait for you to hit apply before updating the parameters.
