Apparently in the last code I posted, I was using 2 different variables to represent the BOMRow's document, by mistake (oBOMRowDoc & oRowDoc). That was likely the main problem.
Since you now have the Item Quantity and the Unit Quantity set up properly, and seem to be getting the proper value in the regular Quantity column, it looks like you just need the value shown in that Quantity column to be copied over to the TOTAL_SQ_INCH column. However, there does not appear to be a Property of the BOMRow object for that value shown in the "QTY" column, so we have to get it the hard way...by attempting to multiply the Unit Quantity (which is returned as a String) by the Item Quantity (which is an Integer representing number of components). Since you can not multiply a String by an Integer, I am using the Val() method in an attempt to extract the Double value from the String, within the multiplication line. Then I attempt to find the custom iProperty named "TOTAL_SQ_INCH". If that is not found, instead of automatically attempting to create it, I changed the code to let the user know about it with a message, then skip to the next BOM row. If that custom iProperty is found, the code now attempts to find a matching Parameter. (I was not sure if you had one or not, or if it was set to exposed/exported.) If it finds that parameter, it will attempt to update its value, which would also automatically update the associated custom iProperty (won't work in the other direction). If the iProperty was found, but the parameter was not found, it then just attempts to update the value of the custom iProperty.
See if this version works for you now.
Sub Main
If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
MsgBox("An Assembly Document must be active for this rule to work. Exiting.", vbCritical, "")
Exit Sub
End If
Dim oADoc As AssemblyDocument = ThisDoc.Document
Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
Dim oBOM As BOM = oADef.BOM
oBOM.PartsOnlyViewEnabled = True
oBOM.StructuredViewEnabled = True
oBOM.StructuredViewFirstLevelOnly = False
Dim oStructuredView As BOMView = oBOM.BOMViews.Item("Structured")
MultiplyBOMColumnValues(oStructuredView.BOMRows)
oADoc.Update
End Sub
Sub MultiplyBOMColumnValues(oBOMRows As BOMRowsEnumerator)
For Each oRow As BOMRow In oBOMRows
If Not oRow.ChildRows Is Nothing Then
MultiplyBOMColumnValues(oRow.ChildRows)
End If
Dim oRowDoc As Document = Nothing
Dim oCD As ComponentDefinition = oRow.ComponentDefinitions.Item(1)
Try
oRowDoc = oCD.Document
Catch oEx As Exception
MsgBox("Failed to get Document from BOMRow Item Number " & oRow.ItemNumber, vbExclamation, "")
Continue For 'skip to next BOMRow
End Try
If IsNothing(oRowDoc) Then Continue For
Dim oCProps As PropertySet = oRowDoc.PropertySets.Item("Inventor User Defined Properties")
'UnitQuantity is derived from BaseUnits & BaseQuantity
Dim oUnitQty As String = oCD.BOMQuantity.UnitQuantity
Dim oItemQty As Integer = oRow.ItemQuantity
'can not access value in "QTY" column directly...no BOMRow property for it
Dim oTotalSqInches As Double = 0.0
'if oUnitQty is set to "Each", this will either fail, or result in wrong result
'can't multiply a String by an Integer, so attempting to extract number from String
If oUnitQty = "Each" Then Continue For 'skip to next BOMRow
Try
oTotalSqInches = (Val(oUnitQty) * oItemQty)
Catch
MsgBox("Multiplying Unit Quantity x Item Quantity Failed!", vbExclamation, "")
End Try
Dim oTotalSQInchProp As Inventor.Property = Nothing
Try
oTotalSQInchProp = oCProps.Item("TOTAL_SQ_INCH")
Catch
MsgBox("A custom iProperty named 'TOTAL_SQ_INCH' was not found in" & vbCrLf & _
"the document associated with BOMRow Item Number " & oRow.ItemNumber, vbExclamation, "")
End Try
If Not IsNothing(oTotalSQInchProp) Then 'if the iProperty was found...
'check if there is a matching Parameter, if so, edit its value instead of the iProperty
Dim oParams As Inventor.Parameters = oRowDoc.ComponentDefinition.Parameters
Dim oParam As Inventor.Parameter = Nothing
Try
oParam = oParams.Item("TOTAL_SQ_INCH")
Catch 'it was not found, so do nothing
End Try
If IsNothing(oParam) Then 'param not found, so edit iProperty value
oTotalSQInchProp.Value = oTotalSqInches
Else 'the parameter was found, so update its value/expession
oParam.Expression = oTotalSqInches.ToString
'which should also update the matching iProperty's value, if it is set to exported/exposed
End If
End If
Next
End Sub
Wesley Crihfield
(Not an Autodesk Employee)
