Parts List File Type Symbol API
evan.wondra
evan.wondra
I am trying to create an iLogic rule that edits a parts list in a drawing document based on what type of file each row is. The parts list knows the difference between assembly, sheet metal, standard part, and content center files because the file type symbol shows in the parts list (see image). Is there any API that allows me to access each of those symbols, basically saying "If that symbol is a content center symbol, then put "CONTENT CENTER" in the description".
Thanks for any help on this.
C_Haines_ENG
If its a parts list than you can just check what kind of file it is. I can throw together some code if you need.
evan.wondra
If you could provide what that API would look like that would be great! It sounds like what I have been looking for.
C_Haines_ENG
This should work:
Sub Main
	Dim oDoc As DrawingDocument = ThisDoc.Document
	Dim oList As PartsList = oDoc.ActiveSheet.PartsLists.Item(1)
	For Each oRow As PartsListRow In oList.PartsListRows
		For Each oBOMRow As DrawingBOMRow In oRow.ReferencedRows
			For Each oCompDef As ComponentDefinition In oBOMRow.BOMRow.ComponentDefinitions
				Select Case oCompDef.Document.DocumentType
					Case kPartDocumentObject
						If oCompDef.IsContentMember
							oRow.Item("DESCRIPTION").Value = "CONTENT CENTER"
						Else
							oRow.Item("DESCRIPTION").Value = "PART"
					Case kAssemblyDocumentObject
						oRow.Item("DESCRIPTION").Value = "ASSEMBLY"
				End Select
			Next
		Next
	Next
End Sub
evan.wondra
Awesome, that worked! Thank you
