Hi, this is an Ilogic code, maybe it could help you for what you're trying to achieve, press escape to get out of the loop.
Dim sFont As String = "ISOCPEUR" ' "ISOCP_IV25"
Dim sFSize1 As Double = 0.3 'font size in cm
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oActiveSheet As Sheet = oDoc.ActiveSheet
Try
Line1 :
' Set a reference to the drawing curve segment.
' This assumes that a drawing curve is selected.
Dim oDrawingCurveSegment As DrawingCurveSegment
oDrawingCurveSegment = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingDefaultFilter, "Select PartComponent")
If oDrawingCurveSegment Is Nothing Then
Exit Sub
Else
' Set a reference to the drawing curve.
Dim oDrawingCurve As DrawingCurve
oDrawingCurve = oDrawingCurveSegment.Parent
' Get the mid point of the selected curve
' assuming that the selected curve is linear
Dim oMidPoint As Point2d
oMidPoint = oDrawingCurve.MidPoint
' Set a reference to the TransientGeometry object.
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
Dim oLeaderPoints As ObjectCollection
oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection
' Create a few leader points.
Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 0.5, oMidPoint.Y - 0.5))
'Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 10, oMidPoint.Y + 5))
' Create an intent and add to the leader points collection.
' This is the geometry that the leader text will attach to.
Dim oGeometryIntent As GeometryIntent
oGeometryIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve)
Call oLeaderPoints.Add(oGeometryIntent)
'oDescription ="<StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "' Bold='True'><Property Document='model' PropertySet='Design Tracking Properties' Property='Description' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='29'>DESCRIPTION</Property></StyleOverride>"
oPartNumber = "<StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "' Bold='True'><Property Document='model' PropertySet='Design Tracking Properties' Property='PartNumber' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='5'>PART NUMBER</Property></StyleOverride>"
' Create text with simple string as input. Since this doesn't use
' any text overrides, it will default to the active text style.
Dim sText As String = oPartNumber '<Br/> "Other text"
Dim oLeaderNote As LeaderNote
oLeaderNote = oActiveSheet.DrawingNotes.LeaderNotes.Add(oLeaderPoints, sText)
oLeaderNote.VerticalJustification = 25601
' Insert a node.
Dim oFirstNode As LeaderNode
oFirstNode = oLeaderNote.Leader.RootNode.ChildNodes.Item(1)
'Dim oSecondNode As LeaderNode
'oSecondNode = oFirstNode.ChildNodes.Item(1)
End If
GoTo Line1
Catch
End Try I hope it can be useful. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
