Announcements
Part Number and Revision in one column in Assembly Bill of Material
Saqib.Iqbal
Saqib.Iqbal
Looking to combine part number and revision in one column in assembly for our ERP system to export BOM from CAD model to ERP system but ERP system set up to have PART number with Revision as a name (example: <part number>-<revision number> or see attachment). Rightnow we copy BOM to Excel and make formula in one column to get what we want but would be good to have it ready in CAD BOM.
Thanks.
smilinger
You can setup an iLogic rule and make the rule run on saving by add it to the Before Save event trigger.
iProperties.Value("Custom", "ABAS") = iProperties.Value("Project", "Part Number") + "-" + iProperties.Value("Project", "Revision Number")
bradeneuropeArthur
No coding needed:
make a new Custom I-Property like:
"ABAS" with the expression"    "=<Part Number>-<Revision Number>"
without "
regards
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Saqib.Iqbal
Thanks all but I got my ilogic code working which add custom iproperty to assembly and all parts in that assembly, so that in BOM when you add that custom iproperties to the table, all parts/subasys have the information you want.
Here is the code, if someone also looking for it like i was:
Dim asmDoc As AssemblyDocument = ThisDoc.Document
iProperties.Value(Model, "Custom", "ABAS PN") = iProperties.Value(Model, "Project", "Part Number") &"-"& iProperties.Value(Model, "Project", "Revision Number")
Dim childDoc As Document
For Each childDoc In asmDoc.AllReferencedDocuments
Try
Dim filename = IO.Path.GetFileName(childDoc.FullFileName)
iProperties.Value(filename, "Custom", "ABAS PN") = iProperties.Value(filename, "Project", "Part Number") &"-"& iProperties.Value(filename, "Project", "Revision Number")
Catch
End Try
Next
If this answer your question, please give it a "KUDOS"
