Part Hole Tolerance Precision
bdeslippe
bdeslippe
Hello All,
Is there a way, via iLogic or with the API, to set the precision of a specific hole's tolerance? I have set the tolerance type like this:
holeFeature.HoleDiameter.Tolerance.SetToFits(ToleranceTypeEnum.kLimitsFitsShowTolerance, fastenerType, "");
But I am not able to set the precision to X.XXX decimal places like you can in the UI. Any suggestions?
Michael.Navara
Property holeFeature.HoleDiameter returns Parameter object. See its Parameter.Precision property. It should be what are you looking for.
bdeslippe
Sweet and simple. Can't believe I missed that.
Thank you very much!
