Parsing the Recent Changes Enum
MechMachineMan
MechMachineMan
I've tried a couple different things but I cant seem to get it to click.
What I want to do is use the RecentChanges property of a document to control when I want a global event trigger to proceed.
I understand that the RecentChanges returns an enum that is an addition of the children that are flagged, but what I can't currently do is establish out of that value which of the children are flagged on without writing a large tree structure.
From the browsing I have done on the msdn site, it looks like enums are set-up to get them to do this for you, in the form of an array, but I can't seem to get it working.
ie; if oDoc.RecentChanges returns a value of 145, I want to find the function/method that spits an array out containing only (128, 16, 1) so then I can do an "If array contains 128 OR ARRAY Contains 32"
Here is the mishmash of things I have tried so far:
Dim oDoc As Document = ThisDoc.Document
''Below fails because it says RecentChanges is not a collection 'For Each i In oDoc.RecentChanges ' MsgBox(i) 'Next
''Below simply returns the value of the combined enums; in my test case, this was 145 (which is 128, 16, 1) MsgBox(CStr(oDoc.RecentChanges))
'Below says that commandtypesenums is not part of ienumerable For Each i In [Enum].Parse(GetType(CommandTypesEnum), oDoc.RecentChanges)
MsgBox(i)
Next
'Below just lists all possible enums in CommandTypesEnum For Each i In [Enum].GetValues(GetType(CommandTypesEnum)) MsgBox(i) Next
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
MechMachineMan
As a temporary solution I just wrote this shoddy function. Which I hate doing; because if there is a native way something can be done, it should be done that way instead of just bringing more redundant code into the world.
Sub Main()
	oRecentChanges = ThisDoc.Document.RecentChanges
    Dim oChangeList As New List(Of Integer)
	MsgBox(CStr(oRecentChanges))
    oChangeList = ParseEnum(oRecentChanges)
	Call PrintList(oChangeList)
End Sub
Function ParseEnum(oVal As Integer) As Object
    Dim oEnumList As New List(Of Integer)
        oEnumList.Add(i)
    Next
    oEnumList.Sort
    oEnumList.Reverse
    Dim oOutputList As New List(Of Integer)
    For Each oItem in oEnumList
        If oVal - oItem > -1 Then
            oVal = oVal - oItem
            oOutputList.Add(oItem)
        End If
    Next
    Return oOutputList
End Function
Sub PrintList(oList As Object)
    For Each oItem in oList
        oStr = oStr & vbLf & oItem
    Next
    MsgBox(oStr)
End Sub
Justin K
