Parameters Inventor iLogic with to Configurator 360
Using Inventor to model products with parameters via iLogic, what do you intend to take advantage of
these parameters in the Configurator 360, however some are not used.
Here are the items that do not work in Configurator 360:
- take advantage of Inventor colors;
- what is the library of items used in Configurator 360, for color;
- which library belongs to adsklib;
MjDeck
Inventor colors work on Configurator 360, but there are some limitations.
Please post a simple model to demonstrate the items that do not work. Or post a link to your model on C360, in the format:
https://configurator360.autodesk.com/6536046632765725870/knnqpbef1tx
Colors from the standard Inventor and Autodesk appearance libraries are available on C360.
If you have a custom adsklib library and your custom colors use texture bitmap files, you have to include the bitmap files in the upload. That's possible only for assembly models, not for parts.
Mike Deck
Software Developer
Autodesk, Inc.
Where can I attach the color library file?
MjDeck
There is no need to attach the adsklib file. To find the appearances, Configurator 360 looks in the actual documents (assemblies and parts). You should make sure that all the required appearances are stored in the documents that use them.
Although you don't need to attach the adsklib file, you do need to attach texture bitmap files that are used by the appearances (if there are any). You can put the bitmap files anywhere in the zip file. It is probably good practice to create a Textures subfolder. As long as they are in the zip, C360 will be able to find them.
Mike Deck
Software Developer
Autodesk, Inc.
