Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Panel Generator - Window Selection Difficulty
0 REPLIES 0
Message 1 of 1
HogueOne
140 Views, 0 Replies
If someone is able to help me solve this problem, it would really make me look good to my boss...
I don't love the way iCopy works, so I've been trying to build my own iLogic tool for rapidly assembling a wall of aluminum panels. The basic idea is that you still start with an adaptive template, select geometry to constrain to, and generate multiple parts. in the example below, I've selected all my bottom, top, left, and right edges with different colors. it detects how many panels to build based on the geometry and generates.
 If you press escape without selecting any geometry for the current group, it prompts you to choose an option from the main menu:
The code isn't pretty, but it works as intended. My problem is that you can only single click curves one at a time. I want to give the user the option to window select curves to speed up the process. the idea is that they would pick all the bottom edges, proceed to the next step, then window select all the horizontal lines. the code has functions in place that do not allow you to pick a curve that has been reserved for a previous group, so in theory it should work.
I've tried implementing code like the example below into my selection process, but it always causes more issues than it solves:
Sub Main
    'create the selectionclass
    Dim oSelection As New clsSelect
    'call the window select sub in the class
    oSelection.WindowSelect(ThisApplication)
    'exit sub if getting the count creates an error ( user escaped with nothing selected)
    Try : iCount = oSelection.SelectedObjects.Count : Catch : Exit Sub : End Try
    MsgBox(iCount & " sketch curve(s) selected.", , "iLogic")
    'You can add your custom logic here to work with the selected sketch curves
    'For example:
    'For Each oSketchCurve As SketchEntity In oSelection.SelectedObjects
    '    ' Do something with each oSketchCurve
    'Next
End Sub
Class clsSelect
    Private WithEvents oInteractEvents As InteractionEvents
    Private WithEvents oSelectEvents As SelectEvents
    Private bTooltipEnabled As Boolean
    Private ThisApplication As Inventor.Application
    Public SelectedObjects As ObjectsEnumerator
    Private stillSelecting As Boolean = True
    Public Sub WindowSelect(oApp As Inventor.Application)
        ThisApplication = oApp
        oInteractEvents = ThisApplication.CommandManager.CreateInteractionEvents
        oInteractEvents.InteractionDisabled = False
        oSelectEvents = oInteractEvents.SelectEvents
        'filter for sketch curves
        oSelectEvents.AddSelectionFilter(SelectionFilterEnum.kSketchCurveFilter)
        oSelectEvents.WindowSelectEnabled = True
        bTooltipEnabled = ThisApplication.GeneralOptions.ShowCommandPromptTooltips
        ThisApplication.GeneralOptions.ShowCommandPromptTooltips = True
        oInteractEvents.StatusBarText = "Select sketch curves. CTRL to deselect, ESC to finish."
        oInteractEvents.Start()
        While stillSelecting
            ThisApplication.UserInterfaceManager.DoEvents()
        End While
    End Sub
    Private Sub oInteractEvents_OnTerminate() Handles oInteractEvents.OnTerminate
        ThisApplication.GeneralOptions.ShowCommandPromptTooltips = bTooltipEnabled
        oSelectEvents = Nothing
        oInteractEvents = Nothing
        stillSelecting = False
    End Sub
    Private Sub oSelectEvents_OnSelect(ByVal JustSelectedEntities As ObjectsEnumerator,
        ByVal SelectionDevice As SelectionDeviceEnum, ByVal ModelPosition As Point,
        ByVal ViewPosition As Point2d, ByVal View As View) Handles oSelectEvents.OnSelect
        SelectedObjects = oSelectEvents.SelectedEntities
    End Sub
    Private Sub oSelectEvents_OnUnSelect(UnSelectedEntities As ObjectsEnumerator,
        SelectionDevice As SelectionDeviceEnum, ModelPosition As Point,
        ViewPosition As Point2d, View As View) Handles oSelectEvents.OnUnSelect
    End Sub
End Class
Could someone help me figure out how to implement this window selection into my project below? I've also attached resources for you to test out. You'll need to put the parts and code in an assembly for it to work. Thank you so much.
Sub Main()
    ExecuteMainLogic()
End Sub
Sub ExecuteMainLogic()
    Dim oAsmDoc As AssemblyDocument = ThisDoc.Document
    Dim templateFile As String = GetTemplateFile(oAsmDoc)
    If templateFile = "" Then Exit Sub
    Dim oSketchCurves As Object() = Nothing
    Dim currentGroupIndex As Integer = 0
    Dim highlightSets(3) As HighlightSet
    Do
        If oSketchCurves Is Nothing Then
            InitializeSketchCurvesAndHighlightSets(oSketchCurves, highlightSets, oAsmDoc)
        End If
        Dim selectionResult As String = SelectSketchCurvesForGroup(oSketchCurves, currentGroupIndex, highlightSets)
        Select Case selectionResult
            Case "Abort"
                ClearAllHighlightSets(highlightSets)
                Exit Sub
            Case "NextGroup"
                If DirectCast(oSketchCurves(currentGroupIndex), List(Of Object)).Count = 0 Then
                    MessageBox.Show("You must select at least one curve in this group before proceeding.", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
                    Continue Do
                End If
                Dim mismatchMessage As String = CheckGroupMismatch(oSketchCurves, currentGroupIndex)
                If mismatchMessage <> "" Then
                    MessageBox.Show(mismatchMessage, "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
                    ' Bring up the main menu after showing the mismatch error
                    Dim menuResult As String = PromptUserForOption(oSketchCurves, highlightSets)
                    Select Case menuResult
                        Case "Continue"
                            Continue Do
                        Case "PreviousGroup"
                            MoveToPreviousGroup(currentGroupIndex, highlightSets)
                        Case "Restart"
                            ResetSelectionProcess(oSketchCurves, currentGroupIndex, highlightSets)
                        Case "Abort"
                            Exit Sub
                        Case Else
                            Continue Do
                    End Select
                    Continue Do
                End If
                If currentGroupIndex = 3 Then
                    ' We're in the last group, check if all groups have at least one curve and match
                    If AllGroupsHaveCurves(oSketchCurves) AndAlso CheckAllGroupsMatch(oSketchCurves) Then
                        ' Prompt for panel generation
                        Dim expectedPanelCount As Integer = DirectCast(oSketchCurves(0), List(Of Object)).Count * DirectCast(oSketchCurves(2), List(Of Object)).Count
                        If MessageBox.Show("Reference geometry established successfully. Do you want to generate " & expectedPanelCount & " panels?", "Generate Panels?", MessageBoxButtons.YesNo, MessageBoxIcon.Question) = DialogResult.Yes Then
                            Dim success As Boolean = ProcessAllGroups(oAsmDoc, templateFile, oSketchCurves, highlightSets)
                            If success Then
                                If MessageBox.Show("All " & expectedPanelCount & " panels were generated successfully. Do you want to add more?", "Add More Panels?", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button2) = DialogResult.Yes Then
                                Else
                                    Exit Sub
                                End If
                            Else
                                ' Handle the case where panel generation failed
                                MessageBox.Show("Panel generation failed. Please try again.", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
                                Continue Do
                            End If
                        Else
                            ' User chose not to generate panels, open the main menu
                                Case "Continue"
                                    Continue Do
                                Case "Restart"
                                Case "Abort"
                                    Exit Sub
                                Case Else
                                    ' Handle other cases as needed
                                    Continue Do
                            End Select
                        End If
                    Else
                        MessageBox.Show("You must select at least one curve in each group and ensure the number of curves match between corresponding groups.", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
                        ' Bring up the main menu after showing the error
                            Case "Continue"
                                Continue Do
                            Case "Restart"
                            Case "Abort"
                                Exit Sub
                            Case Else
                                Continue Do
                        End Select
                        Continue Do
                    End If
                Else
                    MoveToNextGroup(currentGroupIndex, highlightSets)
                End If
            Case "Restart"
            Case "Continue"
                ' Just continue the loop
            Case "Error", "NoEdgesSelected"
                ' Handle these cases as needed, possibly by showing an appropriate message
                Continue Do
            Case "Success"
                ' This case is now handled in the "NextGroup" section
                currentGroupIndex += 1
        End Select
        If currentGroupIndex = 4 Then
            ' This case is now handled in the "NextGroup" section above
            currentGroupIndex = 3 ' Keep it at the last group
            Continue Do
        End If
    Loop
End Sub
Sub InitializeSketchCurvesAndHighlightSets(ByRef oSketchCurves As Object(), ByRef highlightSets() As HighlightSet, oAsmDoc As AssemblyDocument)
    oSketchCurves = New Object(3) {}
    For i As Integer = 0 To 3
        oSketchCurves(i) = New List(Of Object)
        highlightSets(i) = CreateColoredHighlightSet(oAsmDoc, GetGroupColor(i))
    Next
End Sub
Sub ClearAllHighlightSets(highlightSets() As HighlightSet)
    For Each HighlightSet In highlightSets
        If HighlightSet IsNot Nothing Then HighlightSet.Clear()
    Next
    ThisApplication.ActiveView.Update()
End Sub
Sub ResetSelectionProcess(ByRef oSketchCurves As Object(), ByRef currentGroupIndex As Integer, highlightSets() As HighlightSet)
    oSketchCurves = Nothing
    currentGroupIndex = 0
End Sub
Sub MoveToPreviousGroup(ByRef currentGroupIndex As Integer, highlightSets() As HighlightSet)
    If currentGroupIndex > 0 Then
        ClearHighlightSet(highlightSets(currentGroupIndex))
        currentGroupIndex -= 1
    Else
        MessageBox.Show("Already at the first group.", "Information")
    End If
End Sub
Sub MoveToNextGroup(ByRef currentGroupIndex As Integer, highlightSets() As HighlightSet)
    If currentGroupIndex < 3 Then
    Else
        MessageBox.Show("Already at the last group.", "Information")
    End If
End Sub
Sub ToggleCurveSelection(groupCurves As List(Of Object), curve As Object, highlightSet As HighlightSet)
    Dim index As Integer = groupCurves.IndexOf(curve)
    If index <> -1 Then
        groupCurves.RemoveAt(index)
        RemoveHighlight(highlightSet, curve)
    Else
        groupCurves.Add(curve)
        highlightSet.AddItem(curve)
    End If
End Sub
Sub ClearHighlightSet(HighlightSet As HighlightSet)
End Sub
Sub RemoveHighlight(HighlightSet As HighlightSet, item As Object)
    On Error Resume Next
    HighlightSet.Remove(item)
    If Err.Number <> 0 Then
        MessageBox.Show("Unable to remove highlight. Error: " & Err.Description, "Error", MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
    End If
    On Error GoTo 0
End Sub
Sub ContinueWithNewTemplate(ByRef oSketchCurves As Object(), ByRef highlightSets() As HighlightSet)
    ' Store the current selection
    Dim tempSketchCurves As Object() = oSketchCurves.Clone()
    ' Clear current highlight sets
    ' Reinitialize with new template
    InitializeSketchCurvesAndHighlightSets(oSketchCurves, highlightSets, ThisDoc.Document)
    ' Restore the selection and highlight states
        oSketchCurves(i) = tempSketchCurves(i)
        Dim groupCurves As List(Of Object) = DirectCast(oSketchCurves(i), List(Of Object))
        For Each curve In groupCurves
            highlightSets(i).AddItem(curve)
        Next
    Next
    ' Update the view to show the restored highlights
End Sub
Sub CreateAndConstrainOccurrence(oAsmDoc As AssemblyDocument, templateFile As String, oPlane As Object, bottomCurve As Object, topCurve As Object, leftCurve As Object, rightCurve As Object, i As Integer, j As Integer)
    Dim newCopyFile As String = CreateCopyOfTemplate(templateFile)
    Dim oOccurrence As ComponentOccurrence = AddOccurrenceToAssembly(oAsmDoc, newCopyFile)
    If oOccurrence Is Nothing Then
        MessageBox.Show("Failed to add occurrence for bottom curve " & (i + 1) & " and left curve " & (j + 1) & ".", "Error")
        Exit Sub
    End If
    oOccurrence.Adaptive = True
    Dim oOccPlaneFront As WorkPlane = GetOccurrencePlane(oOccurrence, "PlaneFront")
    If oOccPlaneFront IsNot Nothing Then
        CreateFlushConstraint(oAsmDoc, oPlane, oOccurrence, oOccPlaneFront)
    End If
    CreateMateConstraint(oAsmDoc, bottomCurve, oOccurrence, "AxisBottom")
    CreateMateConstraint(oAsmDoc, topCurve, oOccurrence, "AxisTop")
    CreateMateConstraint(oAsmDoc, leftCurve, oOccurrence, "AxisLeft")
    CreateMateConstraint(oAsmDoc, rightCurve, oOccurrence, "AxisRight")
End Sub
Sub CreateFlushConstraint(oAsmDoc As AssemblyDocument, oPlane As Object, oOccurrence As ComponentOccurrence, oOccPlane As WorkPlane)
    Dim oOccPlaneProxy As WorkPlaneProxy
    oOccurrence.CreateGeometryProxy(oOccPlane, oOccPlaneProxy)
    Dim oFlushConstraint As FlushConstraint
    oFlushConstraint = oAsmDoc.ComponentDefinition.Constraints.AddFlushConstraint(oPlane, oOccPlaneProxy, 0)
End Sub
Sub CreateMateConstraint(oAsmDoc As AssemblyDocument, curve As Object, oOccurrence As ComponentOccurrence, axisName As String)
    Dim oOccAxis As WorkAxis = oOccurrence.Definition.WorkAxes.Item(axisName)
    Dim oOccAxisProxy As WorkAxisProxy
    oOccurrence.CreateGeometryProxy(oOccAxis, oOccAxisProxy)
    oAsmDoc.ComponentDefinition.Constraints.AddMateConstraint(curve, oOccAxisProxy, 0)
End Sub
Sub SetDocumentParameter(doc As Document, paramName As String, value As String)
    Dim param As Parameter = Nothing
    param = doc.ComponentDefinition.Parameters.UserParameters.Item(paramName)
    On Error GoTo 0
    If param Is Nothing Then
        doc.ComponentDefinition.Parameters.UserParameters.AddByValue(paramName, value, UnitsTypeEnum.kTextUnits)
    Else
        param.Expression = """" & value & """"
    End If
End Sub
Sub CreateAdaptiveOccurrences(oAsmDoc As AssemblyDocument, templateFile As String, oPlane As Object, oSketchCurves() As Object)
    Dim bottomCurves As List(Of Object) = DirectCast(oSketchCurves(0), List(Of Object))
    Dim topCurves As List(Of Object) = DirectCast(oSketchCurves(1), List(Of Object))
    Dim leftCurves As List(Of Object) = DirectCast(oSketchCurves(2), List(Of Object))
    Dim rightCurves As List(Of Object) = DirectCast(oSketchCurves(3), List(Of Object))
    If Not ValidateCurveCounts(bottomCurves, topCurves, leftCurves, rightCurves) Then Exit Sub
    For i As Integer = 0 To bottomCurves.Count - 1
        For j As Integer = 0 To leftCurves.Count - 1
            CreateAndConstrainOccurrence(oAsmDoc, templateFile, oPlane, bottomCurves(i), topCurves(i), leftCurves(j), rightCurves(j), i, j)
        Next
    Next
End Sub
Function GetTemplateFile(oAsmDoc As AssemblyDocument) As String
    Dim paramName As String = "LastUsedTemplatePath"
    Dim lastUsedPath As String = GetDocumentParameter(oAsmDoc, paramName)
    If lastUsedPath <> "" AndAlso System.IO.File.Exists(lastUsedPath) Then
        Dim result As DialogResult = MessageBox.Show("Do you want to use the same template as last time?" & vbNewLine & "Path: " & lastUsedPath, "Use Previous Template?", MessageBoxButtons.YesNoCancel)
        If result = DialogResult.Yes Then
            Return lastUsedPath
        ElseIf result = DialogResult.Cancel Then
            Return ""
        End If
    End If
    Dim selectedFile As String = SelectFile()
    If selectedFile <> "" Then
        SetDocumentParameter(oAsmDoc, paramName, selectedFile)
        Return selectedFile
    End If
    Return lastUsedPath ' Return the last used path if no new file was selected
End Function
Function SelectFile() As String
    Dim oFileDlg As Inventor.FileDialog = Nothing
    ThisApplication.CreateFileDialog(oFileDlg)
    oFileDlg.InitialDirectory = "C:\"
    oFileDlg.Filter = "Inventor Files (*.ipt; *.iam)|*.ipt; *.iam|All Files (*.*)|*.*"
    oFileDlg.DialogTitle = "Select a template file"
    oFileDlg.CancelError = True
    oFileDlg.ShowOpen()
        MessageBox.Show("File selection canceled.", "Error")
        Return ""
    ElseIf oFileDlg.FileName = "" Then
        MessageBox.Show("No file selected.", "Error")
        Return ""
    End If
    On Error GoTo 0
    Return oFileDlg.FileName
End Function
Function SelectSketchCurvesForGroup(ByRef oSketchCurves As Object(), groupIndex As Integer, highlightSets() As HighlightSet) As String
    Dim curveGroups As String() = {"Bottom", "Top", "Left", "Right"}
    Dim groupCurves As List(Of Object) = DirectCast(oSketchCurves(groupIndex), List(Of Object))
    Dim firstCurveSketch As Sketch = If(groupCurves.Count > 0, groupCurves(0).Parent, Nothing)
    ThisApplication.StatusBarText = "Select edges for the " & curveGroups(groupIndex) & " group. Press Esc when done."
    Try
        While True
            Dim curve As Object = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchCurveFilter, "Select edges for the " & curveGroups(groupIndex) & " group (Esc when done)")
            If curve Is Nothing Then
                If groupCurves.Count > 0 Then
                    ' User pressed Esc after selecting at least one curve
                    System.Windows.Forms.Application.DoEvents()
                    System.Threading.Thread.Sleep(200)
                    Return "NextGroup"
                Else
                    ' No curves selected, open the menu
                    Dim result As String = PromptUserForOption(oSketchCurves, highlightSets)
                    If result = "Abort" Then
                        If MessageBox.Show("Are you sure you want to abort operation?", "Confirm Abort", MessageBoxButtons.YesNo, MessageBoxIcon.Question) = DialogResult.Yes Then
                            Return "Abort"
                        Else
                            Continue While
                        End If
                    ElseIf result <> "Continue" Then
                        Return result
                    End If
                End If
            Else
                If firstCurveSketch Is Nothing Then
                    firstCurveSketch = curve.Parent
                End If
                If curve.Parent Is firstCurveSketch Then
                    ' Check if the curve is already used in a previous group
                    Dim isUsed As Boolean = False
                    For i As Integer = 0 To groupIndex - 1
                        If DirectCast(oSketchCurves(i), List(Of Object)).Contains(curve) Then
                            isUsed = True
                            Exit For
                        End If
                    Next
                    If Not isUsed Then
                        ToggleCurveSelection(groupCurves, curve, highlightSets(groupIndex))
                    End If
                End If
            End If
        End While
    Catch ex As Exception
        Return "Error"
    End Try
    If groupCurves.Count = 0 Then
        Return "NoCurvesSelected"
    End If
    Return "Success"
End Function
Function GetGroupColor(groupIndex As Integer) As Inventor.Color
    Select Case groupIndex
        Case 0 ' Bottom
            Return ThisApplication.TransientObjects.CreateColor(0, 0, 255) ' Blue
        Case 1 ' Top
            Return ThisApplication.TransientObjects.CreateColor(255, 255, 0) ' Yellow
        Case 2 ' Left
            Return ThisApplication.TransientObjects.CreateColor(255, 0, 0) ' Red
        Case 3 ' Right
            Return ThisApplication.TransientObjects.CreateColor(0, 255, 0) ' Green
        Case Else
            Return ThisApplication.TransientObjects.CreateColor(255, 255, 255) ' White
    End Select
End Function
Function PromptUserForOption(ByRef oSketchCurves As Object(), ByRef highlightSets() As HighlightSet) As String
    Dim options As String() = {
        "Continue",
        "Back",
        "Restart",
        "Change Template"
    Dim selectedOption As String = InputListBox("Select an option:", options, options(0), "Main Menu")
    Select Case selectedOption
        Case "Continue"
            Return "Continue"
        Case "Back"
            Return "PreviousGroup"
        Case "Restart"
            Return "Restart"
        Case "Change Template"
            Dim newTemplate As String = SelectFile()
            If newTemplate <> "" Then
                SetDocumentParameter(ThisDoc.Document, "LastUsedTemplatePath", newTemplate)
                ContinueWithNewTemplate(oSketchCurves, highlightSets)
                Return "Continue"
            Else
                Return PromptUserForOption(oSketchCurves, highlightSets)
            End If
        Case Else
            Return "Abort"
    End Select
End Function
Function GetOccurrencePlane(oOccurrence As ComponentOccurrence, planeName As String) As WorkPlane
    Dim oOccPlane As WorkPlane
    oOccPlane = oOccurrence.Definition.WorkPlanes.Item(planeName)
    On Error GoTo 0
    If oOccPlane Is Nothing Then
        MessageBox.Show("Geometric entity '" & planeName & "' cannot be found. Aborting operation.", "Error")
    End If
    Return oOccPlane
End Function
Function CheckMatchingCounts(groupIndex As Integer, groupCurves As List(Of Object), oSketchCurves() As Object) As Boolean
    If (groupIndex = 1 AndAlso groupCurves.Count <> oSketchCurves(0).Count) OrElse _
       (groupIndex = 3 AndAlso groupCurves.Count <> oSketchCurves(2).Count) Then
        Dim message As String = "The number of " & curveGroups(groupIndex) & " curves doesn't match the number of " & _
                                IIf(groupIndex = 1, "Bottom", "Left") & " curves. An error occurred because the numbers don't match."
        MessageBox.Show(message, "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
        Return False
    End If
    Return True
End Function
Function ValidateCurveCounts(bottomCurves As List(Of Object), topCurves As List(Of Object), leftCurves As List(Of Object), rightCurves As List(Of Object)) As Boolean
    If bottomCurves.Count <> topCurves.Count Then
        MessageBox.Show("The number of bottom and top curves must be the same.", "Error")
        Return False
    End If
    If leftCurves.Count <> rightCurves.Count Then
        MessageBox.Show("The number of left and right curves must be the same.", "Error")
        Return False
    End If
    Return True
End Function
Function CreateCopyOfTemplate(originalFile As String) As String
    Dim fso As Object = CreateObject("Scripting.FileSystemObject")
    Dim folder As String = fso.GetParentFolderName(originalFile)
    Dim baseName As String = fso.GetBaseName(originalFile)
    Dim extension As String = fso.GetExtensionName(originalFile)
    Dim newFile As String
    Dim randomSuffix As String
    Do
        randomSuffix = GenerateRandomSuffix(8)
        newFile = folder & "\" & baseName & "-" & randomSuffix & "." & extension
    Loop While fso.FileExists(newFile)
    fso.CopyFile(originalFile, newFile)
    If fso.FileExists(newFile) Then
        Return newFile
    Else
        Return ""
    End If
End Function
Function GenerateRandomSuffix(length As Integer) As String
    Dim chars As String = "ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789"
    Dim random As New Random()
    Dim result As String = ""
    For i As Integer = 1 To length
        result &= Chars(random.Next(0, chars.Length))
    Next
    Return result
End Function
Function AddOccurrenceToAssembly(oAsmDoc As AssemblyDocument, filePath As String) As ComponentOccurrence
    oOccurrence = oAsmDoc.ComponentDefinition.Occurrences.Add(filePath, ThisApplication.TransientGeometry.CreateMatrix())
        MessageBox.Show("Failed to add the selected file as an occurrence.", "Error")
    End If
    Return oOccurrence
End Function
Function GetDocumentParameter(doc As Document, paramName As String) As String
    On Error GoTo 0
    If param IsNot Nothing Then
        Return CStr(param.Value)
    Else
        Return ""
    End If
End Function
Function CheckGroupMismatch(oSketchCurves As Object(), currentGroupIndex As Integer) As String
    If currentGroupIndex = 1 OrElse currentGroupIndex = 3 Then
        Dim previousGroup As Integer = If(currentGroupIndex = 1, 0, 2)
        Dim currentCount As Integer = DirectCast(oSketchCurves(currentGroupIndex), List(Of Object)).Count
        Dim previousCount As Integer = DirectCast(oSketchCurves(previousGroup), List(Of Object)).Count
        If currentCount <> previousCount Then
            Dim difference As Integer = Math.Abs(currentCount - previousCount)
            If currentCount > previousCount Then
                Return "The amount of edges in this group does not match the previous group. You need to deselect " & difference & " edge(s)."
            Else
                Return "The amount of edges in this group does not match the previous group. You need to select " & difference & " more edge(s)."
            End If
        End If
    End If
    Return ""
End Function
Function CheckAllGroupsMatch(oSketchCurves As Object()) As Boolean
    Return DirectCast(oSketchCurves(0), List(Of Object)).Count = DirectCast(oSketchCurves(1), List(Of Object)).Count AndAlso
           DirectCast(oSketchCurves(2), List(Of Object)).Count = DirectCast(oSketchCurves(3), List(Of Object)).Count
End Function
Function AllGroupsHaveCurves(oSketchCurves As Object()) As Boolean
        If DirectCast(oSketchCurves(i), List(Of Object)).Count = 0 Then
            Return False
        End If
    Next
    Return True
End Function
Function GetSketchPlane(firstCurve As Object) As Object
    Dim sketch As Sketch = firstCurve.Parent
    Return sketch.PlanarEntity
End Function
Function CreateColoredHighlightSet(doc As Document, Color As Inventor.Color) As HighlightSet
    Dim HighlightSet As HighlightSet = doc.CreateHighlightSet
    HighlightSet.Color = Color
    Return HighlightSet
End Function
Function ProcessAllGroups(oAsmDoc As AssemblyDocument, templateFile As String, oSketchCurves() As Object, highlightSets() As HighlightSet) As Boolean
    Dim oPlane As Object = GetSketchPlane(oSketchCurves(0)(0))
    If oPlane Is Nothing Then
        Return False
    End If
    CreateAdaptiveOccurrences(oAsmDoc, templateFile, oPlane, oSketchCurves)
    Return True
End Function
Labels (7)
0 REPLIES 0
