I prepare code to delete all drawing dimension. But I have a problem with ordinate dimension.
When I have drawing with this kind of dimension my rule have error like on gif.
If I delete ordinate dimension manually (del key) everthing is ok.
Can you help me what is wrong ??
My code:
Dim oDoc As DrawingDocument oDoc = ThisApplication.ActiveDocument Dim oSheet As Sheet oSheet = oDoc.ActiveSheet 'delete sheet formats Dim oCurrentNumber As Sheet oCurrentNumber = oDoc.ActiveSheet ' Iterate through the sheets, and delete the title blocks and symbols For Each oSheet In oDoc.Sheets oSheet.Activate Try oSheet.TitleBlock.Delete Catch 'catch error if no border found End Try Try oSheet.Border.Delete Catch 'catch error if no border found End Try Next 'set back to original sheet oCurrentNumber.Activate 'CLEAR DRAWING Dim oCL As Centerline Dim oCM As Centermark Dim oBalloon As Balloon Dim oThreadNote As HoleThreadNote Dim oOrdDim As OrdinateDimension Dim oDrawingDim As DrawingDimension For Each oSheet In oDoc.Sheets oSheet.Activate For Each oCL In oSheet.Centerlines 'If oCL.Attached = False oCL.Delete 'End if 'Centerline attached Next 'Centerline For Each oCM In oSheet.Centermarks 'If oCL.Attached = False oCM.Delete 'End if 'Centermarks attached Next 'Centermarks For Each oBalloon In oSheet.Balloons 'If oBalloon.Attached = True oBalloon.Delete 'End If 'Baloon attached Next 'Balloon For Each oThreadNote In oSheet.DrawingNotes.HoleThreadNotes 'If oBalloon.Attached = False oThreadNote.Delete 'End If 'Baloon attached Next 'Balloon For Each oSymbol In oSheet.SketchedSymbols 'look for the symbol by name 'If oSymbol.Name = "UWAGA: 1" Then oSymbol.Delete 'End If Next For Each oOrdDim In oSheet.DrawingDimensions.OrdinateDimensions 'If oOrdDim.Attached = False oOrdDim.Delete 'End If 'Baloon attached Next For Each oDrawingDim In oSheet.DrawingDimensions 'If oDrawingDim.Attached = False Then Call oDrawingDim.Delete 'End If Next Next
I try delete this dimension by :
unfortunetly something go wrong.
Someone help me ??
Thanks in advance
ralfmj
