Order Sketch Symbols by name
HI all,
in Inventor Drawing, is it possible to "reorder" the sketch symbols list by symbol name?
Thanks, best regards
Massimo
bshbsh
Yes, but you need to expand it first I think. And it may cause graphical glitches in the browser. (At least it does here.) It also needs to be selected.
DrwDoc.BrowserPanes.Item(1).TopNode.BrowserNodes.Item("Drawing Resources").BrowserNodes.Item("Sketch Symbols").Expanded = True
DrwDoc.BrowserPanes.Item(1).TopNode.BrowserNodes.Item("Drawing Resources").BrowserNodes.Item("Sketch Symbols").DoSelect
ThisApplication.CommandManager.ControlDefinitions.Item("DrawingResourceSort").Execute
DrwDoc.BrowserPanes.Item(1).TopNode.BrowserNodes.Item("Drawing Resources").Expanded = False
(Node names are localized.)
MechMachineMan
Literally had a solution posted yesterday that solves this...
https://forums.autodesk.com/t5/inventor-customization/copy-sketched-symbols-with-folders/td-p/713142...
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
