optimized selection option stop working
This is about a very anoing problem.
Without a reason the "optimised selection" option stopped working and the only way to choose another part,from a assembly is to use the " select other option".
After several different and unsuccessful attempts to recover the original state of the "optimised selection" (messing with Win 10 Pro performance options,installing Inventor 2016 Pro ect. :slightly_smiling_face: ) what work for me was changing the "optimized selections" time delay options from 1,7 sec to 0,9 sec.
I would like to know is this just a isolated case  or it is a problem which needed a solution from Autodesk?
S2DL,
I was searching for some help with this topic as mine in IV2016 had stopped after a new install on a new computer.
Hope you got yours working.  Its been since January, so I assume you have, but I thought I would reply with my results as no one else has.
Open a 2nd session of Inventor while the first session is open.
I havent actually tried that.  Here is what happened.  When I got the new system, reinstalled IV2016, my optimize was not working, it is set at 1.5 seconds delay.  I also have 2017 installed (waiting till all in company are up to date to use it) so I opened 2017 to see if it worked there.  It did.  Flipped back to 2016, and now it was working.  Closed 2017 and optimized is still working.  I havent closed and restarted 2016 yet to see.  If it fails I'll let you know.
