Open each document for view and close inside assembly.
K.TRYFONIDIS
K.TRYFONIDIS
I am trying to make an external rule that will run only in an assembly document and will open each of the documents inside of it (.iam and .ipt ) view them for 3 sec then save and close, after move to next one.
i am trying to use a code like this one but i don't get it to run.
Dim referencedDocs As DocumentsEnumerator = asmDoc.AllReferencedDocuments
    For Each doc As Document In referencedDocs
        If doc.DocumentType = kPartDocumentObject Or doc.DocumentType = kAssemblyDocumentObject Then
            OpenAndViewDocument(doc)
            Thread.Sleep(5000) ' View each document for 5 seconds
            CloseDocument(doc)
Andrii_Humeniuk
Hi @K.TRYFONIDIS . Try this code:
Sub main()
	Dim oAsmDoc As AssemblyDocument = ThisDoc.FactoryDocument
	Dim oDocs As Documents = ThisApplication.Documents
	Dim oRefDocs As DocumentsEnumerator = oAsmDoc.AllReferencedDocuments
	If oRefDocs.Count = 0 Then Exit Sub
	For Each oRefDoc As Document In oRefDocs
		Dim oDoc As Document = oDocs.Open(oRefDoc.FullDocumentName, True)
		System.Threading.Thread.Sleep(5000)
		If oDoc.IsModifiable Then oDoc.Save()
		oDoc.Close()
	Next
End Sub
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
K.TRYFONIDIS
it works pretty good, only problem is that i want to rotate the parts for those 5 sec, and when i run the code its like frozen.
Andrii_Humeniuk
You cannot use the program while running the code, but you can for example add a 360 degree rotation around the Y axis to the code.
K.TRYFONIDIS
did a slight change to your code.
it works perfect.
this code is being combined with a trigger ilogic to save custom thumbnails of the part ( you can rotate with spacemouse if you have one )
Open documents code.
Imports System.Threading
Sub Main()
Dim startTime As DateTime = DateTime.Now
Do While DateTime.Now.Subtract(startTime).TotalSeconds < 5
' Allow interaction with the model for 5 seconds
ThisApplication.UserInterfaceManager.DoEvents()
Loop
oDoc.Close()
Next
Interaction.MsgBox("Success! All referenced documents have been opened, viewed, saved, and closed.", MsgBoxStyle.Information, "iLogic Rule")
End Sub
Code to trigger before save.
Imports System.Drawing
Imports System.Drawing.Imaging
' Rule to run only for IPT and IAM files
Sub MAIN
    Dim m_Doc As Inventor.Document
    m_Doc = ThisDoc.Document
    If m_Doc.DocumentType <> kAssemblyDocumentObject _
        And m_Doc.DocumentType <> kPartDocumentObject Then
        MessageBox.Show("File is not a model.", "iLogic")
        Return 'exit rule
    End If
    ' Get current color scheme name
    Dim oColorSchemeName As String
    oColorSchemeName = ThisApplication.ActiveColorScheme.Name
    ' Get current color scheme background type
    Dim oBackGroundType As BackgroundTypeEnum
    oBackGroundType = ThisApplication.ColorSchemes.BackgroundType
    ' Change to Deep Blue (Presentation)
    ThisApplication.ColorSchemes.Item("Presentation").Activate
    ' Set to use one color background type
    ThisApplication.ColorSchemes.BackgroundType = BackgroundTypeEnum.kOneColorBackgroundType
    ' Save the active view as an image directly
    Dim m_Camera As Inventor.Camera = ThisApplication.ActiveView.Camera
    Dim m_TO As Inventor.TransientObjects = ThisApplication.TransientObjects
    Dim m_CV As Inventor.View = ThisApplication.ActiveView
    Dim m_PrevMode As Integer = m_CV.DisplayMode
    Dim m_Disp3D As Boolean = ThisApplication.DisplayOptions.Show3DIndicator
    m_CV.DisplayMode = Inventor.DisplayModeEnum.kShadedWithEdgesRendering
    ThisApplication.DisplayOptions.Show3DIndicator = False
    m_CV.Update
    ' Set the image path and name
    Dim oPath As String = "folder to save\IMAGES\"
    Dim oFileName As String = System.IO.Path.GetFileNameWithoutExtension(m_Doc.FullFileName) ' Get the file name without extension
    Dim oFile As String = oPath & oFileName & ".png"
    ' Save the image
    m_Camera.SaveAsBitmap(oFile, 800, 600, m_TO.CreateColor(255, 255, 255))
    m_CV.DisplayMode = m_PrevMode
    ThisApplication.DisplayOptions.Show3DIndicator = m_Disp3D
    m_CV.Update
    ' Change back to the original color scheme using the name
    ThisApplication.ColorSchemes.Item(oColorSchemeName).Activate
    ' Change back to the original background type
    ThisApplication.ColorSchemes.BackgroundType = oBackGroundType
End Sub
