- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
A quick example of how to open a drawing from a balloon.
Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument While True 'select Balloon Dim oBalloon As Balloon = Nothing oBalloon = ThisApplication.CommandManager.Pick _ (SelectionFilterEnum.kDrawingBalloonFilter, _ "Select a balloon to open a it's drawing. " & " (press ESC To Exit selection)") If IsNothing(oBalloon) Then Exit While Dim oLeader As Leader If oBalloon IsNot Nothing Then oLeader = oBalloon.Leader Dim oLeaderNode As LeaderNode = oLeader.AllNodes(oLeader.AllNodes.Count) Dim oIntent As GeometryIntent = oLeaderNode.AttachedEntity Dim oCurve As DrawingCurve = oIntent.Geometry Dim oProxy As EdgeProxy = oCurve.ModelGeometry Dim oOcc As ComponentOccurrence = oProxy.ContainingOccurrence Dim oRefDoc As Document = oOcc.Definition.Document Dim oFilePath As String = oRefDoc.FullFileName() Dim oDrawingFilePath As String = Left(oFilePath, Len(oFilePath) -3) & "idw" Try oDrawDoc = ThisApplication.Documents.Open(oDrawingFilePath, True) Exit While Catch MsgBox("Could not open " & oDrawingFilePath, , "iLogic") End Try End While
Join me at AU 2026
MFG1053: AI Tips and Tricks for iLogic and the Inventor API
MFG2514: A Panel of Experts on Rule Management and Automation Excellence
