Open Drawing from Balloon
Curtis_Waguespack
Curtis_Waguespack
A quick example of how to open a drawing from a balloon.
@harvey3ELEA
Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
While True
	'select Balloon
	Dim oBalloon As Balloon = Nothing
	oBalloon = ThisApplication.CommandManager.Pick _
	(SelectionFilterEnum.kDrawingBalloonFilter, _
	"Select a balloon to open a it's drawing. " & " (press ESC To Exit selection)")
	If IsNothing(oBalloon) Then Exit While
	Dim oLeader As Leader
	If oBalloon IsNot Nothing Then oLeader = oBalloon.Leader
	Dim oLeaderNode As LeaderNode = oLeader.AllNodes(oLeader.AllNodes.Count)
	Dim oIntent As GeometryIntent = oLeaderNode.AttachedEntity
	Dim oCurve As DrawingCurve = oIntent.Geometry
	Dim oProxy As EdgeProxy = oCurve.ModelGeometry
	Dim oOcc As ComponentOccurrence = oProxy.ContainingOccurrence
	Dim oRefDoc As Document = oOcc.Definition.Document
	Dim oFilePath As String = oRefDoc.FullFileName()
	Dim oDrawingFilePath As String = Left(oFilePath, Len(oFilePath) -3) & "idw"
	Try
		oDrawDoc = ThisApplication.Documents.Open(oDrawingFilePath, True)
		Exit While
	Catch
		MsgBox("Could not open " & oDrawingFilePath, , "iLogic")
	End Try
End While
harvey3ELEA
Now that's nice!  I did notice, however, the code doesn't like balloons that are on tangent surfaces, such as a pipe.  When I move the balloon to the pipe's cut edge, it performs the task properly.
Here's what I see when clicking on a tangent-connected balloon:
Curtis_Waguespack
@harvey3ELEA , good catch, see this updated version
While True
	'select Balloon
	"Select a balloon to open it's drawing. " & " (press ESC To Exit selection)")
	Dim oOcc As ComponentOccurrence = oCurve.ModelGeometry.ContainingOccurrence
	Try
		Exit While
	Catch
	End Try
End While
harvey3ELEA
Success!  That did the trick.
The boss is impressed at how I'm now able to use Inventor drawings more effectively with you're recent codes.  His first comment:  why doesn't Inventor already have those built in?
Thanks, Harvey
DMOTS1
Thanks everyone!
DMOTS1
Thanks!
DeptaM
Hello, thank you for this rule. It's absolutely great.
Martin
