Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
OnFileSaveAsDialog Event Not Being Caught After API Upgrade
5 REPLIES 5
etckerry
581 Views, 5 Replies
Hello all,
I found that the add-in we've been maintaining for the last 10+ years was still referencing Autodesk.Inventor.Interop.dll v16.0. I tried updating it to v24.2, and while everything compiles just fine, the OnFileSaveAsDialog event is not longer being caught. Other events (document save, document open, document initialize, etc.) all seem to be fine. I tried using several other API versions, going all the way back to 17.0 and they all appear to have this issue.
Some other posts reporting similar issues:
https://forums.autodesk.com/t5/inventor-customization/inventor-2022-onfilesaveasdialog-event/m-p/103...
https://forums.autodesk.com/t5/inventor-customization/onfilesaveasdialog-event-problem/m-p/8151528
I'm using Inventor 2020 and VB.NET.
Based on the first link above, I thought I might try disabling all of the additional add-ins. This didn't fix the issue. Other than the add-in I develop, no other 3rd party add-ins are installed anyway.
My symptoms were a little different than the second link above (the add-in loads on startup automatically just fine), but I tried updating the GUID as a long shot. No change.
Any ideas?
Kerry
Labels (2)
5 REPLIES 5
can you upload the vb.net project with the  add-in?
Arthur Knoors
Autodesk Affiliations:
It took a bit to thin it out, but the attached project does demonstrate the issue. To reproduce:
1. Create new file -> observe message box for "OnActivate" appear twice
2. Click save -> expect message box for "OnFileSaveAsDialog" but instead get standard save as dialog
Kerry
etckerry
in reply to: etckerry
After some experimenting, I was able to determine the cause of my issue, although I still don't understand why. In case it helps anyone, I had to switch the "Embed Interop Types" option to "False" for the autodesk.inventor.interop reference.
This is done by expanding "References" under the relevant project in the Solution Explorer pane, then selecting "autodesk.inventor.interop." In the Properties pane (if not docked, right-click on "autodesk.inventor.interop" and choose "Properties"), switch "Embed Interop  Types" to "False."
-Kerry
wood.isbell
Thanks for this! I feel like an idiot because I have run into this in the past when moving to a more recent API version. Much hair pulling averted by your follow-up.
davide_orlando
Thank you so much @etckerry! you have resolve very stranger issue fo r mee too!
