Non-Integer values in QTY field on Assembly BOM
I would like to see the Static Value in the QTY field on a Structured BOM in an assembly file be allowed to enter a Non-Integer value (Decimal - E.G. 12.857) instead of a Integer value (E.G. 12) only.  This is a static value only, why is that qty field only allowed to have integer values.
My case for this is my company uses raw materials in house and we need to calculate raw material values to a decimal point and be able to transfer that information to our ERP system.  The Non-Integer values would be a great addition to the Inventor program to allow for seamless transfers of information.
bradeneuropeArthur
You need to change de bom quantity settings in the document settings of the file.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Thank you very much for that bit of information. I dug a little more into that how the document settings work and got the answer I was looking for.
bradeneuropeArthur
Was my solution the answer to your question?
please mark it as solved than!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
