New to Inventor
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
My code either gives me catastrophic error or says my values are not double. Any tips?
' Prompt the user for the part OD Dim partOD As Double partOD = CDbl(InputBox("Enter the Part OD:", "Part OD Input")) ' Set dimensions based on part OD If partOD > 0 And partOD <= 2.25 Then size = 3.5 sizec = 3.5 sizeb = 3.5 sizet = 3.5 ElseIf partOD > 2.25 And partOD <= 3.5 Then size = 4.75 sizec = 4.75 sizeb = 4.75 sizet = 4.75 ElseIf partOD > 3.5 And partOD <= 4.5 Then size = 6.0 sizec = 6.0 sizeb = 6.0 sizet = 6.0 ElseIf partOD > 4.5 And partOD <= 6.25 Then size = 7.75 sizec = 7.75 sizeb = 7.75 sizet = 7.75 ElseIf partOD > 6.25 And partOD <= 8.0 Then size = 9.75 sizec = 9.75 sizeb = 9.75 sizet = 9.75 ElseIf partOD > 10 And partOD <= 12 Then size = 14.0 sizec = 14.0 sizeb = 14.0 sizet = 14.0 End If ' Set other dimensions based on the sizes If size = 3.5 Then zdiameter = 3.245 zdiameterc = 3.245 zdiameterb = 3.245 zdiametert = 3.245 maxpindiameter = 1.125 maxpindiameterc = 1.125 maxpindiameterb = 1.125 maxpindiametert = 1.125 ElseIf size = 4.75 Then zdiameter = 4.495 zdiameterc = 4.495 zdiameterb = 4.495 zdiametert = 4.495 maxpindiameter = 1.125 maxpindiameterc = 1.125 maxpindiameterb = 1.125 maxpindiametert = 1.125 ElseIf size = 6.0 Then zdiameter = 5.745 zdiameterc = 5.745 zdiameterb = 5.745 zdiametert = 5.745 maxpindiameter = 1.5 maxpindiameterc = 1.5 maxpindiameterb = 1.5 maxpindiametert = 1.5 ElseIf size = 7.75 Then zdiameter = 7.495 zdiameterc = 7.495 zdiameterb = 7.495 zdiametert = 7.495 maxpindiameter = 1.75 maxpindiameterc = 1.75 maxpindiameterb = 1.75 maxpindiametert = 1.75 ElseIf size = 9.75 Then zdiameter = 9.495 zdiameterc = 9.495 zdiameterb = 9.495 zdiametert = 9.495 maxpindiameter = 1.875 maxpindiameterc = 1.875 maxpindiameterb = 1.875 maxpindiametert = 1.875 ElseIf size = 14.0 Then zdiameter = 13.745 zdiameterc = 13.745 zdiameterb = 13.745 zdiametert = 13.745 maxpindiameter = 2.75 maxpindiameterc = 2.75 maxpindiameterb = 2.75 maxpindiametert = 2.75 End If ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("size").Value = size ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("sizec").Value = sizec ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("sizeb").Value = sizeb ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("sizet").Value = sizet ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("zdiameter").Value = zdiameter ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("zdiameterc").Value = zdiameterc ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("zdiameterb").Value = zdiameterb ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("zdiametert").Value = zdiametert ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("maxindiameter").Value = maxpindiameter ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("maxpindiameterc").Value = maxpindiameterc ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("maxpindiameterb").Value = maxpindiameterb ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("maxpinDiametert").Value = maxpindiametert
