New part event - vb.net addin
Eyal.Admon
Eyal.Admon
I have an addin that adds a button to launch a simple sub.
I want to have the sub run everytime the user creates a new part.
when i create a new part nothing happens.
i have this in my code:(only showing relevent stuff)
 Public module Globals
    Public m_inventorApplication As Inventor.Application
Public Class StandardAddInServer
    Private WithEvents m_AppEvents As FileUIEvents
public sub activate
  m_inventorApplication = addInSiteObject.Application
  m_AppEvents = m_inventorApplication.FileUIEvents
and i'm trying to run this sub:
Private Sub m_AppEvents_Onnewfile(TemplateDir As String, ParentHWND As Long, TemplateFileName As String, Context As NameValueMap, HandlingCode As HandlingCodeEnum) Handles m_AppEvents.OnFileNewDialog Event
msgbox("new file")
End Sub
Thanks.
yan.gauthier
you need to subscribe to the event.
I am unsure of how it would be done in VB.NET, but here is an example in C#:
AddInServer.InvApp.ActiveEditDocument.DocumentEvents.OnChangeSelectSet += DocumentEvents_OnChangeSelectSet;
private void DocumentEvents_OnChangeSelectSet(EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
            if (BeforeOrAfter == EventTimingEnum.kAfter)
                if (AddInServer.InvApp.ActiveEditDocument.SelectSet.Count == 1 && AddInServer.InvApp.ActiveEditDocument.SelectSet[1] is ComponentOccurrence componentOccurrence)
                    syncContext.Post(o => eSForm.ReloadViewModel(componentOccurrence, new ESModel(componentOccurrence)), null);
            HandlingCode = HandlingCodeEnum.kEventNotHandled; // Let inventor do his things
according to this source, you need to use the AddHandler keywords in order to do something similar
https://stackoverflow.com/questions/7220438/subscribing-events-in-vb-net
WCrihfield
When coding with vb.net, there are two main ways to set-up event 'listeners'/handlers.  (AddHandler...,AddressOf... / RemoveHandler...,AddressOf...) & (WithEvents / Handles).  When using 'WithEvents & Handles', you must declare the WithEvents variable at the level above the Sub that is to 'handle' the event, not within another Sub at the same level.  When using AddHandler, RemoveHandler & AddressOf, you can use them within different subs at the same level.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you have time, please... Vote For My IDEAS 💡or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
Eyal.Admon
Hi, thank you for your reply...
I got the addin to catch an OnActivateDocument event with this:
        Implements Inventor.ApplicationAddInServer
        Private m_inventorApplication As Inventor.Application
        Dim WithEvents m_AppEvents As ApplicationEvents
   Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate
                m_AppEvents = m_inventorApplication.ApplicationEvents
end sub
Private Sub m_AppEvents_OnActivateDocument(ByVal DocumentObject As Inventor._Document, ByVal BeforeOrAfter As Inventor.EventTimingEnum, ByVal Context As Inventor.NameValueMap, ByRef HandlingCode As Inventor.HandlingCodeEnum) Handles m_AppEvents.OnActivateDocument
            MsgBox("test")
        End Sub
I still cant catch a new part event though...
Eyal.Admon
Thanks for the reply.
i got this to work with:
        Dim WithEvents e_AppEvents As FileUIEvents
                e_AppEvents = m_inventorApplication.FileUIEvents
end sub
 Private Sub e_AppEvents_Onnewfile() Handles e_AppEvents.OnFileNewDialog
            MsgBox("new file")
        End Sub
