Announcements
New Hatch Patterns for Inventor 2018
thayek12
thayek12
I'm new to the forums and I did a search to find how to create a new hatch pattern but didn't see anything specific for Inventor 2018.  I'm working with composite panels and I'd like to create/import a honeycomb hatch pattern to use in my drawing section views.  I have spent most of my 3D/2D design time in a different modeling program and it had a more extensive pre-defined hatch pattern selection than Inventor does.
So my question is:
is there a tutorial on how to create your own hatch pattern and is there a place I can download pre-defined additional hatch patterns or user created hatch patterns that would expand my current library?
Thanks for the help.
Tim
hugha
You can use AutoCAD pattern in Inventor. Viz:
https://knowledge.autodesk.com/support/inventor-products/getting-started/caas/CloudHelp/cloudhelp/20...
We keep links to hatch pattern collections here:  http://hatchkit.com.au/HatLinks.php
hope this helps
Hugh Adamson
HermJan.Otterman
https://www.mgfx.co.za/blog/building-architectural-design/how-to-add-a-hern-in-autocad/
edit the hatch, from the list choose other, than you can load *.pat files
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
