Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
New Hatch Patterns for Inventor 2018
thayek12
thayek12
I'm new to the forums and I did a search to find how to create a new hatch pattern but didn't see anything specific for Inventor 2018.  I'm working with composite panels and I'd like to create/import a honeycomb hatch pattern to use in my drawing section views.  I have spent most of my 3D/2D design time in a different modeling program and it had a more extensive pre-defined hatch pattern selection than Inventor does.
So my question is:
is there a tutorial on how to create your own hatch pattern and is there a place I can download pre-defined additional hatch patterns or user created hatch patterns that would expand my current library?
Thanks for the help.
Tim
hugha
You can use AutoCAD pattern in Inventor. Viz:
https://knowledge.autodesk.com/support/inventor-products/getting-started/caas/CloudHelp/cloudhelp/20...
We keep links to hatch pattern collections here:  http://hatchkit.com.au/HatLinks.php
hope this helps
Hugh Adamson
HermJan.Otterman
https://www.mgfx.co.za/blog/building-architectural-design/how-to-add-a-hern-in-autocad/
edit the hatch, from the list choose other, than you can load *.pat files
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
