Announcements
Need to control user parameters dimensions angle dim with level of detail (Lod)
infobala86
infobala86
I need to control angle dimension with lod in main assembly
WCrihfield
Just checking...You know that is precisely what the Positional Representation is for, right?
Wesley Crihfield
(Not an Autodesk Employee)
infobala86
Thanks for your response, the above problem solved by view representation itself no need to workout with lod and all.
WCrihfield
If you problem is solved, you can click the "Accept As Solution" on your last response, to close out this issue.
Tip:  Using the Design View Representations is almost always preffered over using Level Of Detail Representations.
Level Of Detail Representations are mostly only used to save memory (RAM) when working with large assemblies.
Wesley Crihfield
