Multiple selections during function
NachoShaw
Advisor Advisor
NachoShaw
Hi
I have made a small tool to repeat a thickening process. The tools requires that I can select multiple faces at once and then I would need to continue. I have most of it done and I'm currently adding my selected parts to a collection however, I cant seem to break of the selection process.
Currently I'm using the ThisApplication.CommandManager.Pick method but it seems that once this function has started, it MUST click something. Can this method be cancelled allowing the function to continue after?
I would prefer something like:
Start function
click a variable amount of faces (keep clicking until I need to stop)
click an ok button or something that can break the picking process
function continues to process the thickening process
Does the Select Class allow this and if so, how can I implement the cancel process?
Cheers
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
This is just a thought and I'm not sure if it will actually work.
What if you made the selection first then ran the function. This way you already have your selection set before you even run the function.
