Multibody parts Renamining bodies with a Rule
chachaman
chachaman
In my multibody workflow, it makes the most sense to pattern bodies inside the multi-body part. Is there a snippet of code ( Rule) that can rename the body so that it derives from the original body ?  Example:  Body1, Body1_copy1, Body1_copy2 etc....
Right now, I have to tediously manually rename all the bodies, as you can see in the image:
Thanks in advance !
Accepted solutions (3)
Replies (41)
C_Haines_ENG
How is "Original Body" Defined? Are you talking about the first solid body in the list?
chachaman
Hello C_Haines,
I hope this image helps explain further:
The first solid : CLP_Em_RN is created buisiness as usual. As the multi body develops, the copies of it are simply patterned without modification.
As the bodies are renamed, the copies are named using the original part as the root of the name and the suffix  copy with a number showing it's quantity of  occurrance.
It would be nice if I could automate the process of renaming only the copies. I would manually name all original bodies and the rule would rename the copies automaically.
I hope that explanation helps.
Thx
C_Haines_ENG
Genuinely the most convoluted thing on the planet to just get the BASE SOLID of a pattern. Incredibly complex for 0 reason. The numbering convention isn't perfect, but it absolutely gets the job done.
Sub Main
	Dim oDoc As PartDocument = ThisDoc.Document
	Dim oDocDef As PartComponentDefinition = oDoc.ComponentDefinition
	Dim BrowserPane As BrowserPane = oDoc.BrowserPanes.Item("Model")
	Dim oParent As String
	Dim SUFFIX As String = "_COPY_"
	Dim oSolids As New Dictionary(Of String, String)
	For Each oNodeA As BrowserNode In BrowserPane.TopNode.BrowserNodes(2).BrowserNodes
		For Each oNodeB As BrowserNode In oNodeA.BrowserNodes
			If InStr(oNodeB.BrowserNodeDefinition.Label, "Pattern of") <> 0 Then
				oParent = Replace(Split(oNodeB.BrowserNodeDefinition.Label, ":")(0), "Pattern of ", "")
				oSolids.Add(oNodeA.BrowserNodeDefinition.Label, oParent)
			End If
		Next
	Next
	For Each oSolid As SurfaceBody In oDocDef.SurfaceBodies
		If oSolids.ContainsKey(oSolid.Name)
			For i = 1 To 100
				Try
					oSolid.Name = oSolids(oSolid.Name) & SUFFIX & i
				Catch
				End Try
			Next
		End If
	Next
End Sub
chachaman
Tried to run the code, but nothing happens. Perhaps I did not deploy it correctly ?  Anyinsights ?
Attached: test File.
Thanks  a bunch  !
C_Haines_ENG
Well that's funny! I was programming on Inventor 2019 which doesn't have Model States, and the program was trying to get the 2nd browser node (which on modern inventor is model states). Try this code:
Sub Main
	For Each oNodeA As BrowserNode In BrowserPane.TopNode.BrowserNodes(3).BrowserNodes
			End If
		Next
	Next
			For i = 1 To 100
				Try
				Catch
				End Try
			Next
		End If
	Next
End Sub
chachaman
Bingo !
It now  works. 😊
How do I buy you a coffee ?  This is above average help !
Thanks again.
C_Haines_ENG
Its no problem! I love the challenge!
If you need it tweaked in the future let me know. Be sure to mark the solution as accepted!
chachaman
OK, I will and thanks again !!!
chachaman
The program is not picking up patterned bodies that are sketch driven ? I attached the culprit file.
Can something be done ?
I attached the file.
Thx
C_Haines_ENG
I should have added in more error correction in the first edition. Same issue as last time, the Solid Body node is in a different position. I got this new code working with your file. It runs much slower but it works.
Sub Main
	Dim oSolidNode As BrowserNode
	For Each oTopNode As BrowserNode In BrowserPane.TopNode.BrowserNodes
		For Each oSubNode As BrowserNode In oTopNode.BrowserNodes
			If oSubNode.BrowserNodeDefinition.Label.Contains("Solid Bodies")
				oSolidNode = oSubNode
				Exit For
			End If
		Next : If oSolidNode IsNot Nothing Then Exit For
	Next
	For Each oNodeA As BrowserNode In oSolidNode.BrowserNodes
			End If
		Next
	Next
			For i = 1 To 100
				Try
				Catch
				End Try
			Next
		End If
	Next
End Sub
chachaman
Hello C_Haines,
It now works !
there is a slight glitch in that if I edit some body names and run it again, the suffixes compound....see image.
have a fix ?
Thx
C_Haines_ENG
That is likely happening because the item it is a copy of has been given the "Copy" suffix. Try renaming the base component to something simple and see if it still happens.
What I mean by this is that the item being copied has likely been accidentally renamed "ITEM_COPY_4". If you rename it to something like "ITEM_1" and rerun the tool it should correct itself. However if you are patterning copies of items then it would cause that problem. If that is the case, I can figure out a workaround.
chachaman
Hi C,
I think what is happening is that a pattern has been re-patterned, and hence  it's building on the existing suffixed name.
Thx
C_Haines_ENG
Could you send the file you are using in the screenshot? You have significantly fewer solids in that one, and I cant seem to replicate the problem in the original file you sent me.
chachaman
Here is the current version of the file....
Thx
C_Haines_ENG
Oh you're gonna love this one. You were correct, you had patterns of patterns. Problem has been fixed, and OPTIMIZED. Guaranteed correct numbering, and it runs much faster. It does however have a 1 in 1,000,000+ chance of failing, part of the fun!
Sub Main
	Dim oSolids As New Dictionary(Of SurfaceBody, String)
	'[ FIND SOLID BODY NODE
				oSolidNode = oSubNode : GoTo FoundNode
			End If
		Next
	Next
	FoundNode :
	'[ GO THROUGH EACH SOLID IN THE SOLIDBODIES NODES BROWSER TO CHECK IF COMPONENT IS A PATTERN OF ANOTHER SOLID
			If oNodeB.BrowserNodeDefinition.Label.Contains("Pattern of")
				Try
					oParent = Replace(Split(Split(oNodeB.BrowserNodeDefinition.Label, ":")(0), "_COPY")(0), "Pattern of ", "")
					oSolids.Add(oNodeA.NativeObject, oParent) :
				Catch : End Try
			End If
		Next
	Next
	'[ RENAME ALL PATTERNED PARTS WITH A 5-6 DIGIT LONG RANDOM NUMBER, AND THEN RENUMBER ALL SOLIDS CORRECTLY
	Dim oMainSolids As New Dictionary(Of String, Integer), oMainName As String
	For i = 1 To 2
		For Each oSolid As SurfaceBody In oSolids.Keys
			oMainName = oSolids(oSolid)
			If i = 1
				If Not oMainSolids.ContainsKey(oMainName) Then oMainSolids.Add(oMainName, 1)
				oSolid.Name = oMainName & SUFFIX & Int(Rnd * 1000000)
			ElseIf i = 2
				oSolid.Name = oMainName & SUFFIX & oMainSolids(oMainName)
				oMainSolids(oMainName) += 1
			End If
		Next
	Next
End Sub
chachaman
It works nicely !
This routine should part of the base program !!!
Thx
chachaman
Hello C,
If a patterned body gets modified, could you exclude the inheritance of the paprent body name.
If that same body modified body has patterned children, can you continue the inheritance sequence, as depicted by the image below.
In the image, GREEN is the original body.
PURPLE is an unmodified patterned body
RED is a modified patterned body. If it has patterned children, the naming with suffix continues.
Thx for letting me know
C_Haines_ENG
Can you attach the file, this one is quite tricky.
