Mold design units
06:39 AM
- Mute
- Permalink
- Report
We are working with mold design in inventor 2016 (but the same was happening in 2013 as well, what we used before).
The desired unit of all our parts is mm. We set the template files from the templates directory within the project to mm, and this works fine for all the manually created files (with the New command), but all files generated by the mold design module (core base, cavity base, master part, work part, runner gate, ejectors, and so on) are in mm.
I'm sure this is also some setting in another template part, but i can't figure out where it is to change it.
Any help would be much appreciated.
Zsolt.
