Modifying an existing sketch arc using VBA
nick.seman
nick.seman
I have the need to update an existing sketch arc via VBA.  I cannot delete and replace it as I have downstream dependencies.  I am almost able to accomplish it by constraining the start, center, and end points to sketch points (based on work points) and then programmatically modifying the locations of the work points - which works except when the curve direction of the arc (left or right) flips.
While I am able to harvest all the information about the existing arc using "SketchArc" I do not see any way to update the definition.
Can anyone provide any ideas or direction on this?
Thanks;
Nickl
JelteDeJong
The properties of an arc seem to be read-only so that means there is no way to change an arc. But you can create a new arc (using the properies of the old arc.) and then delete the old arc.
the fuction to create an arc has a optional (boolean) paramater to tell Inventor to draw the arc clock or counter clock wise. In the following example I draw 2 arcs. the first is clockwise and the other countercockwise. Notice the boolean at the end of line 6 and 7.
Dim otg = ThisApplication.TransientGeometry
Dim doc As PartDocument = ThisDoc.Document
Dim sketch As Sketch = doc.ComponentDefinition.Sketches.Add(doc.ComponentDefinition.WorkPlanes.Item(1))
sketch.Edit()
Dim arc1 = sketch.SketchArcs.AddByCenterStartEndPoint(otg.CreatePoint2d(0, 0), otg.CreatePoint2d(10, 0), otg.CreatePoint2d(0, 10), True)
Dim arc2 = sketch.SketchArcs.AddByCenterStartEndPoint(otg.CreatePoint2d(-1, -1), otg.CreatePoint2d(9, -1), otg.CreatePoint2d(-1, 9), False)
Jelte de Jong
Blog: hjalte.nl - github.com
nick.seman
That is pretty much what I had arrived at as well.   Problem is that it breaks my downstream processes if I create a new arc and delete the exisitng.  I think I might be able to change my approach to manipulating the work points' locations that the existing arc follows.
Thanks for looking at it for me.
Nick
bradeneuropeArthur
Could you demonstrate with maybe pictures what you try to modify?
Arthur Knoors
Autodesk Affiliations:
JelteDeJong
Moving the arc by manipulating the sketch points seems possible:
sketch.Edit()
MsgBox("Now move.")
arc1.CenterSketchPoint.MoveTo(otg.CreatePoint2d(1, 1))
arc1.StartSketchPoint.MoveTo(otg.CreatePoint2d(11, 1))
arc1.EndSketchPoint.MoveTo(otg.CreatePoint2d(1, 11))
Jelte de Jong
