Models iproperties for titleblock
I am using the model's iproperties to fill in my titleblock. I guess it is a well known way to handle this titleblock information?
I would like to modify this information from the drawing (dwg) without every time have to open the assembly or part that is displayed in the drawing. Is that possible? I am sure this is an often asked request?
BR, Johan
dgreatice
Hi, yes it possible.
please give specific information what do you want.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Thx.
The models always contain the same custom iproperties that are used to fill in the titleblock
ACME_TITLE
ACME_DESCRIPTION
ACME_DRAWING
ACME_SIZE
ACME_TYPE
dgreatice
try this:
oDoc = ThisDrawing.ModelDocument
oCustPropSet = oDoc.PropertySets(4)
For Each oProp In oCustPropSet
Select Case oProp.Name
Case "ACME_TITLE"
ValueProp = InputBox("ACME_TITLE", "INPUT FIELD", oProp.value)
oProp.value = ValueProp
Case "ACME_DESCRIPTION"
ValueProp = InputBox("ACME_DESCRIPTION", "INPUT FIELD", oProp.value)
Case "ACME_DRAWING"
ValueProp = InputBox("ACME_DRAWING", "INPUT FIELD", oProp.value)
Case "ACME_SIZE"
ValueProp = InputBox("ACME_SIZE", "INPUT FIELD", oProp.value)
Case "ACME_TYPE"
ValueProp = InputBox("ACME_TYPE", "INPUT FIELD", oProp.value)
End Select
Next
odoc.Save
Thanks, it kind of works, but it is not that stable. i mean, there is no real-time update between the model's iproperties and the titleblock information. Sometimes all iproperties are blank after running and cancelling your script.
dgreatice
add more line after oDoc.Save:
InventorVb.DocumentUpdate()
