Model States weights don't transfer to the drawings
RyanRausch
RyanRausch
I have one part that has multiple model states.  The idea was that every model state would have its own drawing.  The only issue that I am having is that the weight stays constant on all the different drawings.  Is there a way to pull the weight from every model state into their own drawing w/o doing some workaround?
Michael.Navara
You need to use value from model not from drawing properties.
You can show physical property MASS or you can define user defined iProperty which differs for each model state. When you use user defined property, you are responsible for value update.
