Model states - Open with visible false does not ensure that I actually open the document in desired model state
CattabianiI
CattabianiI
Screencast: https://autode.sk/3tKFzuA
Steps to reproduce the issue:
Open a part and activate model state B, save and close.
Open an assembly containing that part with model state A active (this cause the factory of the part to be present in the Application.Documents list with model state B active)
Execute the attached rule:
open non-visible the part in the master model state.
get from that factory document an iProperty and you'll see that the value is from model state B.
I would like to add some other things:
Open with visible false does not set the Document.Open property to true and this is not changed from previous Inventor, but I don't know it this is correct in Inv 2022.
I got an iProperty just to show the issue, but a more critical api which is not working is ReferencedDocumentDescriptors.
The open visible false issue is the reason behind this bug report ( @m.maertens6DTZT , you can reproduce your problem sistematically if you have the original component that you're iLogic-placing opened in an assembly or a drawing.)
Sub main()
	Dim alreadyOpenedDOc As Document
	Try
		alreadyOpenedDOc = ThisApplication.Documents.ItemByName("path\to\the\part.ipt")
	Catch
	End Try
	Dim doc As Document
	If alreadyOpenedDOc IsNot Nothing
		doc = alreadyOpenedDOc
			MsgBox("ALREADYOPENED" & vbNewLine & doc.FullDocumentName & vbNewLine &
	" IsModelStateFactory: " & doc.ComponentDefinition.IsModelStateFactory & vbNewLine &
	" IsModelStateMember: " & doc.ComponentDefinition.IsModelStateMember & vbNewLine &
	" ModelStateName: " & doc.ModelStateName & vbNewLine &
	" ActiveModelStateName: " & doc.ComponentDefinition.ModelStates.ActiveModelState.Name & vbNewLine &
	" Open: " & doc.Open.ToString & vbNewLine &
	" Is dirty: " & doc.Dirty.ToString)
	End If
	doc = ThisApplication.Documents.Open("path\to\the\part.ipt", False)
	MsgBox(doc.FullDocumentName & vbNewLine &
	Dim props As PropertySet = doc.PropertySets.Item("Inventor Summary Information")
	MsgBox("TITLE: " & props.Item("Title").Value)
'	MsgBox(doc.ReferencedDocumentDescriptors.Count())
'	For Each dd As DocumentDescriptor In doc.ReferencedDocumentDescriptors
'		MsgBox(dd.FullDocumentName)
'		If dd.ReferenceMissing
'			MsgBox("MISSING")
'		End If
'	Next
End Sub
Replies (0)
