- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I would like to mirror an entire folder containing .ipt files.
Not sure how to do this through iLogic, but someone pointed out using the derive mirror option might be a possibility.
I got this far but it doesn't work, if anyone can help me that would be great, left some comments in the code.
Imports System.Windows.Forms
Imports System
Sub Main
oInvApp = ThisApplication
Dim oTemplate As String = "X:\CAD_3D\00 - Inventor standaard (NIET AANKOMEN)\Templates\Standard.ipt"
Dim oFBD = New FolderBrowserDialog()
oFBD.ShowDialog()
Dim oSFolder = oFBD.SelectedPath
If String.IsNullOrEmpty(oSFolder) Then Exit Sub
Dim oFiles() As String = IO.Directory.GetFiles(oSFolder, "*.ipt")
If oFiles.Length = 0 Then Exit Sub
Dim i As Integer = 0
For Each oFile In oFiles
Dim oFileName As String = IO.Path.GetFileName(i)
Call MirDer(oFiles(i))
i = i + 1
Next
End Sub
Dim oInvApp = ThisApplication
Private Function MirDer(ByVal oFileName As String)
Dim CopyDoc As PartDocument = oInvApp.Documents.Add(kPartDocumentObject, oTemplate, False)
Dim oRefComps As ReferenceComponents = CopyDoc.ComponentDefinition.ReferenceComponents
Dim oDerivedPartDef As DerivedPartDefinition
'something wrong here because i used oDerivedAssemblyDef and simply changed it to PartDef
'The mirroring still needs to be put in the code
'Any origin plane would be ok
oDerivedPartDef = oRefComps.DerivedPartComponents.CreateDefinition(oFileName)
oDerivedPartDef.DeriveStyle = DerivedComponentStyleEnum.kDeriveAsMultipleBodies
oDerivedPartDef.IncludeAllTopLevelWorkFeatures = DerivedComponentOptionEnum.kDerivedExcludeAll
oDerivedPartDef.IncludeAllTopLevelSketches = DerivedComponentOptionEnum.kDerivedExcludeAll
oDerivedPartDef.IncludeAllTopLeveliMateDefinitions = DerivedComponentOptionEnum.kDerivedExcludeAll
oDerivedPartDef.IncludeAllTopLevelParameters = DerivedComponentOptionEnum.kDerivedExcludeAll
Dim oDerivedAss As DerivedPartComponent
oDerivedAss = oRefComps.DerivedAssemblyComponents.Add(oDerivedPartDef)
Call oDerivedAss.BreakLinkToFile()
CopyDoc.SaveAs(oSFolder & "\" & oFileName & "_Bsideadjust.ipt", False)
CopyDoc.Close(True)
End Function
