Mirror body rule, how to mirror all bodies
michael.bouwer
michael.bouwer
hi
i found a rule for mirroring bodies in a part
i modified it a bit to suit what i want to do with it
could you guys help me out. the rule is only mirroring the last solid body
its counting the no of solids but using that number as the body to mirror
how would one get it select all solids in the part?
	oFile = ThisDoc.PathAndFileName(False)
'Save a copy of the file
ThisDoc.Document.SaveAs(oFile + "_Mirror" + ".ipt", False)
'Count the Solid bodies in the part file
oFile3 = ThisApplication.ActiveDocument
oSolidBodyCounter = oFile3.ComponentDefinition.SurfaceBodies.Count
	Dim oDoc As PartDocument
	oDoc = ThisApplication.ActiveDocument
	Dim oCol As ObjectCollection
	oCol = ThisApplication.TransientObjects.CreateObjectCollection
	oCol.Add (oDoc.ComponentDefinition.SurfaceBodies(oSolidBodyCounter))
	Dim oPlane As WorkPlane
	oPlane = oDoc.ComponentDefinition.WorkPlanes(1)
	Dim oMirror As MirrorFeature
	oMirror = oDoc.ComponentDefinition.Features.MirrorFeatures.Add(oCol, oPlane, True, kOptimizedCompute)
'Save the new Mirrored Part File
	MessageBox.Show("the model has been mirrored", "mirrored")
dalton98
You are getting a total count of the solid bodies (i.e. 3). You would want to add all of the surface bodies to the collection object (1,2, and 3). I didnt test it but it looks like that is your problem.
oSolidBodyCounter = 3
For i = 1 To oSolidBodyCounter
	oCol.Add(oDoc.ComponentDefinition.SurfaceBodies(i))
Next
michael.bouwer
i does'nt seam to want to add a second object to the collection.
get this error
Error in rule: Rule0, in document: 2920-0903-002_BC_Mirror_Mirror_Mirror_Mirror_Mirror_Mirror_Mirror_Mirror.ipt
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
i tried adding the bodies 1 at a time but get the same error (part has 3 bodies)
i.e.
oCol.Add(oDoc.ComponentDefinition.SurfaceBodies(2))
oCol.Add(oDoc.ComponentDefinition.SurfaceBodies(3))
michael.bouwer
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/mirror-multible-solids-with-ilogic/m...
looks like its an issue with 2019/2020 versions
not ideal but descent solution is to make multiple mirror features
