Memory Usage Apprentice (will not close an opened file)
Dear All,
I'm making a rule that compares some info between two folders with the same part(name)s.
The rule does what it has to do. (i've tested the rule with smaller folders)
The real comparison is between two folders.
- 4286 stp-files
- 29.510 ipt-files
There are two problems that I run into:
1. Mainproblem: (second part of the rule) it opens the file with Apprentice, but it doesn't close it. After approx.4000 files my system memory is used 100% and goes very slow till it eventually crashes at approx 7000 files. (As seen in the picture you can see that the parts counter in the right bottom corner is going up)
2. Small thing I don't like: (First part of the rule) normally when closing ipt-files I used "oFile.Close" but this doesn't seem to work with opened stp-files. So now I use "ThisApplication.ActiveDocument.Close(True)" This works but if, for some reason, the file with the rule becomes the active document. It will close that with a catastrophic failure. Is there a way to still use a kind of "oFile.Close" so that I am sure the stp-file is closed?
'Name of Rule: Compare_stp_vs_ipt(EXCEL)
'Tooltip: Tool to compare stp-files with parts
'Needed for subdirectories
Imports System.IO
'Define stuff
Dim oList_stp As New List(Of String)
Dim oList_ipt As New List(Of String)
Dim oListResults As New List(Of String)
Dim oListFaults As New List(Of String)
Dim oProcessPath_stp As String
Dim oProcessPath_ipt As String
Dim invApprentice As New Inventor.ApprenticeServerComponent
'Location+Name Log file
oExceldoc = "C:\20190129 - Compare_stp-ipt\Log_V5_(Excel).xlsx"
'Location Step-files
oProcessPath_stp = "C:\20190129 - Compare_stp-ipt\Step-files"
'Location ipt-files
oProcessPath_ipt = "C:\20190129 - Compare_stp-ipt\ipt-files"
'[ Get Information stp-files
'Get the files in the specified directory
For Each oDir In System.IO.Directory.GetDirectories(oProcessPath_stp)
    For Each oFilename In System.IO.Directory.GetFiles(oDir & "\", "*.stp")
        'Don't process this folder
        If oFilename.IndexOf("05=CW-panels and Frameworks") = -1 Then
            'True = Opens visible
            'False = Opens unvisible
            oFile = ThisApplication.Documents.Open(oFilename, True)
            Try
            Dim oPartDoc As PartDocument
            oPartDoc = oFile
            oPartDoc.ComponentDefinition.Material = oPartDoc.Materials("Default")
            'Update iProperties Physical
            ThisApplication.CommandManager.ControlDefinitions.Item("AppUpdateMassPropertiesCmd").Execute
            'Get Partnumber
            Try
            oPartnumber = oFile.Displayname
            Catch
            oPartnumber = ""
            End Try
            'Get Mass
            Try
            oMass = Round(oFile.PropertySets.Item("Design Tracking Properties").Item("Mass").Value, 9)
            Catch
            oMass = ""
            End Try
            'Get Area
            Try
            oArea = Round(oFile.PropertySets.Item("Design Tracking Properties").Item("SurfaceArea").Value, 9)
            Catch
            oArea = ""
            End Try
            'Get Volume
            Try
            oVolume = Round(oFile.PropertySets.Item("Design Tracking Properties").Item("Volume").Value, 9)
            Catch
            oVolume = ""
            End Try
            'PrincipalMomentsOfInertia (3)
            'XYZMomentsOfInertia (6)
            Dim Moment(2) As Double
            oFile.ComponentDefinition.MassProperties.PrincipalMomentsOfInertia (Moment(0), Moment(1), Moment(2))
            'Get Inertial Properties: Principal Moments: I1
            Try
            oPM1 = CStr(Round(Moment(0), 8))
            Catch
            oPM1 = ""
            End Try
            'Get Inertial Properties: Principal Moments: I2
            Try
            oPM2 = CStr(Round(Moment(1), 8))
            Catch
            oPM2 = ""
            End Try
            'Get Inertial Properties: Principal Moments: I3
            Try
            oPM3 = CStr(Round(Moment(2), 8))
            Catch
            oPM3 = ""
            End Try
            oArguments = oPartnumber & "/" & oMass & "/" & oArea & "/" & oVolume & "/" & oPM1 & "/" & oPM2 & "/" & oPM3
            oList_stp.Add(oArguments)
            Catch
            oListFaults.Add(oFilename)
            End Try
            'close the file
            'oFile.Close 'doesn't work in opened stp-files
            ThisApplication.ActiveDocument.Close(True) 'Second option
    Next
Next
oList_stp.sort()
MessageBox.Show(oList_stp.Count & " stp-files are processed, Now ipt-files will start", "Title")
'[ Get information ipt-files
For Each oDir In System.IO.Directory.GetDirectories(oProcessPath_ipt)
    For Each oFilename In System.IO.Directory.GetFiles(oDir & "\", "*.ipt")
        If oFilename.IndexOf("OldVersions") = -1 Then
            Try
            oFile = invApprentice.Open(oFilename)
            oPartDoc = oFile
            TempMaterial = oPartDoc.ComponentDefinition.Material.Name 'Get Current material
            oPartDoc.ComponentDefinition.Material = oPartDoc.Materials("Default") 'Temporary change Material
            'Get Partnumber
            Try
            Catch
            oPartnumber = ""
            End Try
            'Get Path
            Try
            oPath = oFilename
            Catch
            oPath = ""
            End Try
            'Get Mass
            Try
            Catch
            oMass = ""
            End Try
            'Get Area
            Try
            Catch
            oArea = ""
            End Try
            'Get Volume
            Try
            Catch
            oVolume = ""
            End Try
            Try
            Catch
            oPM1 = ""
            End Try
            Try
            Catch
            oPM2 = ""
            End Try
            Try
            Catch
            oPM3 = ""
            End Try
            oArguments = oPartnumber & "[" & oPath & "]" & "/" & oMass & "/" & oArea & "/" & oVolume & "/" & oPM1 & "/" & oPM2 & "/" & oPM3
            oList_ipt.Add(oArguments)
            'Put old material back
            oPartDoc.ComponentDefinition.Material = oPartDoc.Materials(TempMaterial)
            Catch
            oListFaults.add(oFilename)
            End Try
            'close the file
            invApprentice.Close()
    Next
Next
oList_ipt.sort()
'[ Compare
For Each oSTP In oList_stp
    For Each oIPT In oList_ipt
        If Left(oSTP,18) = Left(oIPT,18) And oSTP.Remove(0,oSTP.IndexOf("/")) <> oIPT.Remove(0,oIPT.IndexOf("/")) Then 'If Name = Name and /iProp <> /iProp
        oListResults.Add(oIPT.Remove(oIPT.IndexOf("/")) & " < < Is not the same as > > " & Left(oSTP,18))
    Next
Next
oListResults.sort()
'[ Put results in Excel
oCell = 1
'Where the Magic Happens
For Each oListResult In oListResults
GoExcel.CellValue(oExceldoc,"Sheet1", "A" & oCell) = oListResult
oCell = oCell + 1
Next
'Uncomment below if you want to put information all parts to excel (Can take more time)
oCell = 1
GoExcel.CellValue(oExceldoc,"Sheet2", "A" & oCell) = oSTP
oCell = oCell + 1
Next
oCell = 1
GoExcel.CellValue(oExceldoc,"Sheet3", "A" & oCell) = oIPT
oCell = oCell + 1
Next
oCell = 1
For Each oFault In oListFaults
GoExcel.CellValue(oExceldoc,"Sheet4", "A" & oCell) = oFault
oCell = oCell + 1
Next
GoExcel.Save
GoExcel.Close
'Tool to open the created excel
booleanParam = InputRadioBox("Do you want to open the list?", "Yes", "No", booleanParam, Title := "List is Done")
If booleanParam = True Then
ThisDoc.Launch(oExceldoc)
clutsa
wouldn't you close oFile not Apprentice? I haven't had a chance to test anything these are just my first thoughts.
            'close the file
oFile.Close() 'invApprentice.Close()
'oFile = Nothing 'try this maybe
'oPart = Nothing
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
Dear,
I've tried all the combinations with:
oFile.Close()
oFile = Nothing
invApprentice = Nothing
But it doesn't close the file or I get the error message "Not Implemented"
Kind regards,
