Measure minimum distance between parts in assembly and fetch XYZ, iLogic/VB code
maciej.wiankowski
maciej.wiankowski
Hi everyone.
I am looking for a solution to my problem:
I want to measure minimum distance between parts in a subassembly at multiple levels and optionally create in places where the measurement takes place. Then I need to fetch coordinates or those points (I don't need them to be shown) and pass them to parameters (XYZ, X'Y'Z') and draw a line between those points so it can be shown later in the drawing. All that can be hard-coded as the assembly won't change. The only thing that changes are distances between parts/subassemblies.
Can anyone help me with it. please?
mcgyvr
@maciej.wiankowski  Can you post your assembly and ipt files and describe specifically where you want this to happen on that model?
maciej.wiankowski
The original files is very complex and massive. I made a simple "proof of concept" assembly for quickness. I would like to examine both scenarios - 1 part from the main assembly to 1 part from the subassebmly and between p2 parts in the same assembly. I coloured them - bascially red to red and green to green part.
Thank you for your interest.
