Material Library
kv5053545
Material Library
kv5053545
I have a question is it possible to enter from code to the library of materials and get all the names of the materials?
Frederick_Law
bradeneuropeArthur
Could you give the library path?
Arthur Knoors
Autodesk Affiliations:
