mass props to 1dp ( 0.1kg)
keithc03GZXH6
keithc03GZXH6
I require the mass props to be reported on the parts list to 1dp ,
I know that I need to update the Document settings / units / linear dim display precision in order to do this
can anyone assist in the code required to perform this update on all parts in an assembly
TIA
Andrii_Humeniuk
Hi @keithc03GZXH6 . Please try this code:
Sub main
	Dim oDoc As Document = ThisDoc.Document
	If TypeOf oDoc Is AssemblyDocument Then
		For Each oRefDoc As Document In oDoc.AllReferencedDocuments
			If Not oRefDoc.IsModifiable Then Continue For
			ChengeLengthDisplayPrecision(oRefDoc.UnitsOfMeasure, 1)
		Next
	Else If TypeOf oDoc Is PartDocument Then
		Dim oPartDoc As Document = oDoc
		If Not oPartDoc.IsModifiable Then Exit Sub
		ChengeLengthDisplayPrecision(oPartDoc.UnitsOfMeasure, 1)
	End If
End Sub
Private Function ChengeLengthDisplayPrecision(ByVal oUOfM As UnitsOfMeasure,
												ByVal i As Integer)
	oUOfM.LengthDisplayPrecision = i
End Function
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
keithc03GZXH6
Andrii
thank you that works as  required
I owe you a drink sir
Keith
