Mass Properties update with Custom LOD
Dear All
please let me know the code (Ilogic / VBA) for updating mass properties with Custom LOD
thanks in advance
V.Sureshkumar
Replies (7)
Xun.Zhang
@Anonymous,
Some thoughts here.
Go through all unsuppressed components and get the physical properties from each components.
Thanks!
Xun
bradeneuropeArthur
Following code will represent you the Mass of the LOD!
Public Sub massprop()
Dim a As AssemblyDocument
Set a = ThisApplication.ActiveDocument
Dim b As MassProperties ' ComponentDefinition
Set b = a.ComponentDefinition.MassProperties
MsgBox b.Mass
End Sub
Arthur Knoors
Autodesk Affiliations:
Dear Bradeneurope
Thanks for the code, its showing the mass properties value, but i like to update the mass properties with Custom LOD through ilogic.
please let me know
BR
bradeneuropeArthur
ThisApplication.CommandManager.ControlDefinitions.Item("AppUpdateMassPropertiesCmd").Execute
Arthur Knoors
Dear Bradeneurope
Thanks for the update, the below code is working in Master LOD which i am already using, but its not working in Custom LOD, please see the attached snap shot
BR
V.Sureshkumar
bradeneuropeArthur
Can you put the value in the iproperty mass?
Arthur Knoors
llorden4
Ever find a solution for this you can share?
Autodesk Inventor Certified Professional
