map xml to user parameters in ilogic or vb
I am trying parse and import parameters from an .xml file into inventor. I've attached the file for reference.
The file I've attached is an output from a home-grown design program for one of the products we use. It spits out this file to be read by our ERP system downstream of Engineering. I would also like to use it to populate my model with parameters so the drawing is generated automatically.
For example, the material_thickness nodes correspond to steel plate thicknesses, and the lenght/width correspond to steel plate rectangular dimensions. There are also bolt diameters and other parameters I would like to read.
I know there is an out of the box import/export xml parameters, but from what I understand the xml has to be formatted a specific way. I would like to map this existing schema to user parameters in my model. If someone could send me an ilogic or vb code snippet that would be great.
Matt
dean.morrison
Matt,
I do a similar thing (import to inventor from xml)
My xml format may be slightly different, but here is some of the code that i use.
I use VBA to do this - example below.
I hope you can figure out what you need to change, based on this example.
Dean.
'I have a reference to Microsoft XML v3.0
xmlfile = "C:\xml.xml" 'Path to xml file
Set objXML = New MSXML2.DOMDocument
objXML.Load xmlfile
'For a normal node
Set xmlElem = objXML.selectSingleNode("//NodeName")
If Not xmlElem Is Nothing Then
oNodeName = xmlElem.Text
End If
'For a node with children
Set xmlElem = objXML.selectNodes("//NodeNamewithchildren")
oNodeNamewithchildren = xmlElem.ChildNodes.Item(0).Text 'index for child node
End IF
'To apply the xml node value to a User Paramater
Dim oFileLocations As FileLocations
Set oFileLocations = ThisApplication.FileLocations
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.Documents.Open(oFileLocations.Workspace & "/Part.ipt")
Dim oPartCompDef As PartComponentDefinition
Set oPartCompDef = oPartDoc.ComponentDefinition
Dim oParams As UserParameters
Set oParams = oPartCompDef.Parameters.UserParameters
oParams.Item("ParameterName").Expression = oNodeName
oParams.Item("ParameterName").Expression = oNodeNamewithchildren
oPartDoc.Save2 (True)
oPartDoc.Close
