Making An .ipt Rule Run From An .iam
ASchlaack
ASchlaack
I need a way to fire rule "Length" in part "Angle" when there is a parameter change in my assembly. How can I do this?
Aaron Schlaack
Autodesk Inventor 2018
Dell Windows 8.1 64 bit Intel(R) Xeon(R) @ 3.50GHz 32GB Ram
rjay75
You have two options depending on how your rules are written in the part.
In your assembly you can have a rule that responds to a parameter change. That rule can then change the part parameter  or run a rule. If the rule in the part is an internal rule written using the parameter name then it will automatically respond to a parameter change in the part. If the rule must be explicitly run then that can be done to.
From the assembly:
Run rule in subcomponent:
iLogicVb.RunRule("Angle", "Length")
Modify a parameter
Parameter("Angle", "length") = 2.0 in
ASchlaack
Thank you, I used the first rule and it worked great!
Aaron Schlaack
