Macro to Print all drawings. Ignoring parts and assemblies in reference.
gustavo.cassel
gustavo.cassel
Hi, I'm Gustavo and i can't get this to work.
I want a macro get the right parts and assemblies. I want to run it into a assembly and print all the drawings, but skipping the parts and assemblies(with his sub-assemblies parts) that is in reference ( BOMStructure = kreference ).
Here's what i have till this moment:
Public Function Print_Idw(oDrgPrintMgr As PrintManager, Impressora As String, Tamanho_Folha)
With oDrgPrintMgr
.Printer = Impressora
.AllColorsAsBlack = True
.ColorMode = kPrintGrayScale
.ScaleMode = kPrintBestFitScale
.PaperSize = Tamanho_Folha
.NumberOfCopies = 1
.Orientation = oDrgPrintMgr.Orientation
'.SubmitPrint
End With
End Function
Public Sub Projeto_VBA_Gustavo()
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MsgBox "Este NÃO é um documento de Montagem!", vbExclamation, "Macro Encerrada!"
Exit Sub
Dim Assembly_Doc As AssemblyDocument
Set Assembly_Doc = ThisApplication.ActiveDocument
Dim oDrawDoc As DrawingDocument
Dim Num_Files As Integer
Num_Files = 0
Dim oRefDocs As DocumentsEnumerator
Set oRefDocs = Assembly_Doc.AllReferencedDocuments
Dim oRefDoc As Document
Dim File_System_Object As Object
Set File_System_Object = CreateObject("Scripting.FileSystemObject")
Dim oAsmCompDef As AssemblyComponentDefinition
Set oAsmCompDef = Assembly_Doc.ComponentDefinition
Dim oCompOcc As ComponentOccurrence
Dim Lista_Impressos As Object
Set Lista_Impressos = CreateObject("System.Collections.ArrayList")
Dim Lista_Asm_Referencia As Object
Set Lista_Asm_Referencia = CreateObject("System.Collections.ArrayList")
Dim Lista_Ipt_Referencia As Object
Set Lista_Ipt_Referencia = CreateObject("System.Collections.ArrayList")
For Each oRefDoc In oRefDocs
Folder_split = Split(oRefDoc.FullFileName, "\")
N_De_Splits = UBound(Folder_split)
oRefDoc_File_Name = Left(Folder_split(N_De_Splits), Len(Folder_split(N_De_Splits)) - 4)
If Len(oRefDoc_File_Name) >= 6 Then
For Each oCompOcc In oAsmCompDef.Occurrences.AllReferencedOccurrences(oRefDoc)
If oCompOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then
If oCompOcc.DefinitionDocumentType = kAssemblyDocumentObject And _
Not Lista_Asm_Referencia.Contains(oRefDoc.FullDocumentName) Then Lista_Asm_Referencia.Add oRefDoc.FullDocumentName
If oCompOcc.DefinitionDocumentType = kPartDocumentObject And _
Not Lista_Ipt_Referencia.Contains(oRefDoc.FullDocumentName) Then Lista_Ipt_Referencia.Add oRefDoc.FullDocumentName
Else
Lista_Asm_Referencia.Contains(oRefDoc.ReferencingDocuments(1).FullDocumentName) Then Lista_Asm_Referencia.Add oRefDoc.FullDocumentName
Not Lista_Ipt_Referencia.Contains(oRefDoc.FullDocumentName) And _
Not Lista_Asm_Referencia.Contains(oRefDoc.ReferencingDocuments(1).FullDocumentName) And _
Not Lista_Impressos.Contains(oRefDoc.FullDocumentName) Then Lista_Impressos.Add oRefDoc.FullDocumentName
Not Lista_Impressos.Contains(oRefDoc.FullDocumentName) Then Lista_Impressos.Add (oRefDoc.FullDocumentName)
Next
Next
Dim i As Long
Debug.Print vbLf & vbLf & "----------> REFERENCE ASSEMBLIES <-----------" & vbLf
For i = 0 To Lista_Asm_Referencia.Count - 1
Debug.Print Lista_Asm_Referencia.Item(i)
Next i
Debug.Print vbLf & vbLf & "----------> REFERENCE PARTS <-----------" & vbLf
For i = 0 To Lista_Ipt_Referencia.Count - 1
Debug.Print Lista_Ipt_Referencia.Item(i)
Next i
Debug.Print vbLf & vbLf & "----------> PARTS/ASSEMBLIES TO PRINT <-----------" & vbLf
Lista_Impressos.Sort
For i = 0 To Lista_Impressos.Count - 1
Debug.Print Lista_Impressos.Item(i)
Next i
If MsgBox("Serão impressos " & Lista_Impressos.Count & " arquivos. Após início NÃO há volta!" & vbLf & _
"Deseja continuar com a impressão? ", vbYesNo + vbExclamation, "Impressão de arquivos .idw") = vbNo Then Exit Sub
Debug.Print vbLf & vbLf & "ARQUIVOS QUE SERÃO IMPRESSOS: " & vbLf
Folder_split = Split(Lista_Impressos(i), "\")
idwPathName = Left(Lista_Impressos(i), Len(Lista_Impressos(i)) - 4) & ".idw"
Debug.Print oRefDoc_File_Name
If File_System_Object.FileExists(idwPathName) = True Then
Set oDrawDoc = ThisApplication.Documents.Open(idwPathName, True)
oDrawDoc.Activate
Idw_Paper_Size = oDrawDoc.ActiveSheet.Border.Name
If Idw_Paper_Size = "A4" Or Idw_Paper_Size = "A3" Then
Print_Idw oDrawDoc.PrintManager, "IMPRESSORA ENGENHARIA", 14341
Else
If Idw_Paper_Size = "A2" Then papel = 14339
If Idw_Paper_Size = "A1" Then papel = 14359
If Idw_Paper_Size = "A0" Then papel = 14357
If MsgBox("Desenho em Folha " & Idw_Paper_Size & "." & vbLf & "Deseja imprimir?", _
vbYesNo + vbQuestion, "Imprimir na Plotter") = vbYes Then _
Print_Idw oDrawDoc.PrintManager, "PLOTTER", papel
oDrawDoc.Close (True)
Next i
MsgBox "Total de " & Lista_Impressos.Count & " arquivos impressos!"
End Sub
Ralf_Krieg
Hello
Can you tell us in detail where you get stuck? A first short test creates the drawing list as I would expect it. I've not tested printing sub itself.
R. Krieg
RKW Solutions
www.rkw-solutions.com
gustavo.cassel
Hello!!
After a couple days of testing i realize that the error was on the method that i choose to list the parts and assemblies that need to be printed. In my case, i changed the code to read the structured view of the BOM and i get what i want. In summary, i needed a code that filter the parts and assemblies that have a name >= 6 digits, and ignore all the BOM kreference parts and assemblies.
Here's the code now and now he is picking the rights parts and assemblies.
Public Sub Bill_of_Materials_Scan(oBOMRows As BOMRowsEnumerator, List_Print, List_Check, List_Qtdy)
Dim oBOMRow As BOMRow
For Each oBOMRow In oBOMRows
Dim oDef As ComponentDefinition
Set oDef = oBOMRow.ComponentDefinitions(1)
Nome_do_Arquivo oDef.Document.FullFileName, oRefDoc_File_Name
If Not List_Print.Contains(oDef.Document.FullFileName) Then List_Print.Add oDef.Document.FullFileName
If Not List_Check.Contains(oRefDoc_File_Name) Then List_Check.Add oRefDoc_File_Name
If Not oBOMRow.ChildRows Is Nothing Then Call Bill_of_Materials_Scan(oBOMRow.ChildRows, List_Print, List_Check, List_Qtdy)
Next
End Sub
With oDrgPrintMgr
.NumberOfCopies = 1
'.SubmitPrint
End With
End Function
Function Nome_do_Arquivo(Path, Doc_Name)
Folder_split = Split(Path, "\")
Doc_Name = Left(Folder_split(N_De_Splits), Len(Folder_split(N_De_Splits)) - 4)
End Function
Exit Sub
Dim oAsm As AssemblyDocument
Set oAsm = ThisApplication.ActiveDocument
Dim oBOM As BOM
Set oBOM = oAsm.ComponentDefinition.BOM
oBOM.StructuredViewEnabled = True
oBOM.StructuredViewFirstLevelOnly = False
Dim oBOMView As BOMView
Set oBOMView = oBOM.BOMViews("Estruturada")
Dim List_to_Print As Object
Set List_to_Print = CreateObject("System.Collections.ArrayList")
Dim List_to_Check As Object
Set List_to_Check = CreateObject("System.Collections.ArrayList")
Call Bill_of_Materials_Scan(oBOMView.BOMRows, List_to_Print, List_to_Check, List_Quantity)
If MsgBox("Serão impressos " & List_to_Print.Count & " arquivos. Após início NÃO há volta!" & vbLf & _
List_to_Print.Sort
For i = 0 To List_to_Print.Count - 1
idwPathName = Left(List_to_Print(i), Len(List_to_Print(i)) - 4) & ".idw"
oDrawDoc.Activate
Else
Next i
MsgBox "Total de " & List_to_Print.Count & " arquivos impressos!"
End Sub
Thank you for reply me! Now im gonna go next and now i need to find the quantity of each part and assembly!
